As delivered
The result of having no cover and no airbox in an area that rains 80% of the time
Fitted a 92 FZR600 engine for now while I try to find pistons & rings(impossible so far) for the 400 engine. Pulled everything apart painted the frame and swingarm black, scored a fox shock for $00.00!!, New upper fork tubes(way too long gotta machine them down) made in Italy with Racetech emulators. 88 GSXR750 rear wheel, Aprila RSVR rear caliper underslung, YZF600 calipers. Cut and raised the rear subframe 1.5" to update the look.
Tucked the tail light in
Modded the upper fairing by sectioning it and laying it back a bit. Again for a more modern look. Also note bars under upper triple. Kinda looking TZ-ish to me
Filled in the headlight hole for now until I figure out a lighting solution. Will post more pics as the build progresses. Final shot of my Trio
Thanks for looking!
Tommy
