I was wondering how the throttle cables are supposed to be attached to the actual throttle handle (grip/starter area). Because when I go to twist my throttle, the cables move in opposite directions also while twisting I get a clicking feeling/noice. When I opened up the throttle housing the cables were both slightly bend and curved but I wasn't sure if they were in the correct way. When I searched the manual to fix this I couldn't find anything..
Wondering if anyone knows how it should be setup?
Throttle Setup?
Throttle Setup?
Thanks,
ASnyder
ASnyder
Re: Throttle Setup?
I found out how it all goes together but I have a new question, is the throttle supposed to spring back to idle position? Because my throttle seems to have to be pushed back into place.snydes wrote:I was wondering how the throttle cables are supposed to be attached to the actual throttle handle (grip/starter area). Because when I go to twist my throttle, the cables move in opposite directions also while twisting I get a clicking feeling/noice. When I opened up the throttle housing the cables were both slightly bend and curved but I wasn't sure if they were in the correct way. When I searched the manual to fix this I couldn't find anything..
Sent from my Nexus 5 using Tapatalk
Thanks,
ASnyder
ASnyder
Re: Throttle Setup?
The throttle MUST snap closed, freely and immediately when the grip is released. Anything else is a hazard to life and limb - yours, and anyone in front of you!
Re: Throttle Setup?
I just learned that I needed to lube up the throttle, which now it snaps back easily.DonTZ125 wrote:The throttle MUST snap closed, freely and immediately when the grip is released. Anything else is a hazard to life and limb - yours, and anyone in front of you!
Thanks,
ASnyder
ASnyder
Re: Throttle Setup?
Heh - sometimes it's easy ...
