Seem to have 2 taps (one broken), 2 levers & no screw & I can't be bothered to pull the tank to try a load.
Fuel tap lever...
John The Hat
Fuel tap lever...
Anybody know (or can measure for us) the size of that damned little screw (#98606-04016) that holds the fuel cock lever on ('89 FZR400) ?
If you can't fix it, you don't own it.
(Andy Pugh said that.)
Evilchicken0
- Level 3.5
Re: Fuel tap lever...
I bought a Yamaha one when I had a 3en2
FZR400RR 3TJ Bimota SB6
I don't see why you would have to pull the tank to try a bunch of screws. What about using some Loctite to hold the lever onto the shaft?
