1,500 lbs Motorcycle Lift/Dolly/Stand
Posted: Sun Jul 20, 2014 8:28 pm
by architect
This is a general question for all sportbikes really. Does anyone have experience with this jack/lifts? There are many brands out there that have slight variation of basically the same thing.
The exhaust will be where most sportbikes will be lifted. Would this be bad? I know initial reaction is to avoid, but would be great if my FZR or GSXR can sit on this. Thanks everyone.
http://www.harborfreight.com/1500-lb-ca ... 60536.html
Re: 1,500 lbs Motorcycle Lift/Dolly/Stand
Posted: Sun Jul 20, 2014 11:39 pm
by thatkid
Probably work fine. Just add some 2x4's so they sit along the frame rails of the FZR and help clear the exhaust.
Posted: Mon Jul 21, 2014 3:22 pm
by ragedigital
I have one for my Suzuki Boulevard. Probably overkill for the FZR... I would prefer Pitbull-type (front/rear) stands for a sportbike though.
Posted: Mon Jul 21, 2014 3:27 pm
by architect
I have front and rear stand. I want it for the dolley/mobility after the bike is up.Single garage so can't afford to have the bike sitting in one spot and blocking off access to areas.
Posted: Tue Jul 29, 2014 7:38 am
by Evilchicken0
I've lifted engines on one of those type, I don't see why it wouldn't work with a bike. Make sure the floor is flat and smooth though otherwise the casters will catch. use some ratchet straps to hold the bike
Posted: Tue Jul 29, 2014 7:40 am
by architect
My garage is a bit slopped. Will probably stick would under to avoid exhaust.
Posted: Sat Aug 02, 2014 6:23 pm
by Fizzinatorr
used a similar brand/type with an old FZR 600 a few times
will work just fine
+1 on good ratchet straps
Posted: Sat Aug 02, 2014 6:29 pm
by architect
Did you use wood to prop it under or sit the bike right on the exhaust?
Posted: Mon Aug 04, 2014 1:39 pm
by Fizzinatorr
Throw a 2X4 in under the exhaust
but i preferred to just slip off the whole exhaust system -just depended on how lazy i was feeling
