Chasing the rattle
Posted: Sat Sep 21, 2013 5:05 am
So I have been using my 1990 3BF for the past weeks, trying to see how good is her condition and what will she be needing in the near future. First question I have to ask is if this engine is known for using oil. I still have the check more carefully, but I think she is using quite a bit of oil (going from top to bottom level on the little oil window in 500-600 miles). Is it normal?
But the main question is the chase of the rattle. I have a engine rattling noise which seems to come from the center of the engine, from the base of the cylinder head. I think I can hear it more clearly from the RH side, but am not sure (will have to take the fairings out to do a proper test). The noise is much more audible when the bike is hot, and almost negligible when it is cold.
I don't have the EXUP valve, and have read about the clutch problem that generates the rattle, but I think that that one would be more audible when cold, not hot. So, am I looking at a bigger engine problem? The bike now has around 22.500 miles on the clock.
TIA,
Rui
TIA,
Rui
