Page 1 of 3
Picked Up an 89 FZR400
Posted: Mon Aug 12, 2013 2:22 am
by ZamboShelby
It's actually an 89 Genesis with a 600cc swap, Fox rear shock, D&D Exhaust.
Sorry for the typo on the title.
The day I picked it up...
IMG_2251 by
shelbysilos, on Flickr
IMG_2255 by
Raising the front back up...
IMG_2320 by
With the platics back on. I need to remove some overspray on the tank...
IMG_2322 by
IMG_2327 by
In the garage
IMG_2329 by
Re: Picked Up a 90 FZR400
Posted: Mon Aug 12, 2013 1:50 pm
by willandrip
Nice job.
Trucks/trailers/other bikes and engine cranes;you will like it on here.
Posted: Mon Aug 12, 2013 2:34 pm
by ragedigital
Nice find!
What year and model is your Suzuki? I assume GSXR, but I could be wrong. I don't recognize the front.
Darrin
Posted: Mon Aug 12, 2013 11:55 pm
by ZamboShelby
willandrip wrote:Nice job.
Thanks! I use the crane for everything. haha! Are you in the UK?
ragedigital wrote:Nice find!
Darrin
It's a 2013 GSXR 1000 - One Million Commemorative Edition #1685 of 1985
More Pictures!
Posted: Tue Aug 13, 2013 1:21 am
by ZamboShelby
Daytime pics!
IMG_2346 by
IMG_2345 by
IMG_2339 by
IMG_2338 by
Re: Picked Up an 89 FZR400
Posted: Tue Aug 13, 2013 8:26 am
by willandrip
Blue spot calipers....... Check.
V&H c/case covers ......Check.
SP 2TK exhaust hanger...Check.
Looking good there.
What is front master cylinder ?
That must be 600 front end ?
Posted: Tue Aug 13, 2013 10:03 am
by Genesis
Very nice looking bike.
Posted: Tue Aug 13, 2013 10:55 pm
by ZamboShelby
willandrip wrote:Blue spot calipers....... Check.
Looking good there.
You're right! It is a 600 front end... I'm thinking about swapping it out for some inverted forks.
Genesis wrote:Very nice looking bike.
Thanks!
Posted: Wed Aug 14, 2013 7:22 am
by Evilchicken0
You might find the original pillion peg will support the can a little further back.
In the UK if you fit a pillion seat you need to have the pegs in place for the MOT test. Take the seat off for the test or make a cover though, and you'll be fine.
Posted: Sun Aug 18, 2013 8:07 pm
by RoadDogma
Looking good!
That exhaust hanger was standard issue on the California (EXUP) 1WG models. I replaced mine with a pillion peg to take my girl for a spin one night, and found the mounting point on the exhaust to be in the same location for either one. I'm guessing you have a Cali model, and the EXUP system has been removed to fit the pillion seat
I haven't had an inspection required to register any of my bikes when (acquired in-state), so I doubt the lack of pillion pegs will be an issue. (Assuming the bike will be registered in the same state as the tow vehicle). Seems as though things are more stringent in the UK.
So, willandrip... Whats up with the 2TK?
Posted: Mon Aug 19, 2013 8:11 am
by Evilchicken0
The Genesis never had an EXUP. The California model looks like a 3EN2 had the EXUP .... the header pipes on these are marked 2TK but the 3EN2 had a different can, (silver alloy) to the 2TK (Black alloy)
I put a 2TK full system on a 3EN2 and the bolt hole for the can was about 25-30mm out (I think it was forward) I found a bit to fit from somewhere
Posted: Mon Aug 19, 2013 5:49 pm
by RoadDogma
Wow...
Okay, well, I was just reporting from the experiences I've had with my bike. My avatar kind of spells it out, but since everyone is sharing pics... Here it is with the EXUP stuff.
...And after I removed it to fit the pillion. (Had to remove the servo to fit the seat).
I don't know, maybe it's a "one-off"... I'm not sure if I should feel fortunate to have the only California FZR400 Genesis/EXUP (1WG) produced, or disappointed that I haven't been able to find any of the 3EN2 variants. Maybe someone else from Cali could provide some clarification on the issue for the sake of accuracy. I'm intrigued...
Hey Evil, have you considered that the issue you observed mounting the 2TK exhaust on the 3EN2 could be due to the variations in the respective sub-frames? Isn't the tail section a little longer on the 3EN2?
Posted: Mon Aug 19, 2013 8:26 pm
So which one are you?
Posted: Tue Aug 20, 2013 12:52 am
by ZamboShelby
RoadDogma wrote:Wow...
Nice! What front forks/tripples did you use? Please share...
Posted: Tue Aug 20, 2013 7:30 am
by Evilchicken0
You're probably right, I'm on this side of the pond so I don't know much about the USA bikes. The 3en2 / 2tk thing isn't a problem any longer I sold the bike.
Nice hair BTW, I bet you use shapoo and stuff
