Page 1 of 2
Aftermarket Levers
Posted: Sat May 18, 2013 8:44 pm
by architect
Do they have aftermarket levers anywhere? Something a bit modern like this: http://www.ebay.com/itm/Short-Brake-Clu ... 52&vxp=mtr
I have small hands and i find it's more comfortable to use this style from my last bike. But I can't seem to find anyone that makes it for the '88 FZR400s. Thanks!
Re: Aftermarket Levers
Posted: Tue May 21, 2013 1:26 pm
by pefrey
I don't think you are going to find anything for the stock master cylinder. If you swap it out for an R6 unit you will have more luck finding aftermarket levers.
Posted: Tue May 21, 2013 8:35 pm
by slickwill
I looked around and didn't find anything. I swapped my entire clutch perch to one from an R6. That way I can use any of the available choices from a current R6. I'm swapping to an R6 master for the same reason...that and the performance upgrade.
Sent from my DROIDX using Tapatalk 2
Posted: Wed May 22, 2013 2:24 pm
by architect
That sucks... so much work just to get the lever closer to the bars ...
Posted: Wed May 22, 2013 4:24 pm
? Swapping the clutch perch is the work of a few minutes. Swapping the brake master is considerably more work, but has a much greater benefit than simply moving the lever closer to the bar.
Posted: Fri May 24, 2013 1:38 am
by architect
Trying to figure out in doing that. Reading the forums and I hearing that the original cables have too much slack for the R6 perch/MC? Can anyone that has done this let me know what they have done exactly? Thanks for helping out a newb.
Posted: Fri May 24, 2013 5:38 am
by slickwill
viewtopic.php?t=10414
I just did it and gave you sorta detailed instructions:)
Posted: Fri May 24, 2013 11:49 am
by architect
Thanks. Unfortunately I'm a complete newb and I required further details :(
Re: Re: Aftermarket Levers
Posted: Mon May 27, 2013 9:49 am
by slickwill
architect wrote:Thanks. Unfortunately I'm a complete newb and I required further details :(
Okay, I'll take a couple extra pics today to help out.
Posted: Mon May 27, 2013 9:14 pm
by architect
Thanks, man.
I'm trying to figure out if I need to use a certain MC for it to work with the FZR. I'm guessing anything from 2007 onwards for both perch and MC will work? Can I use the same cables or are the lengths not correct? Do I need to bring calipers over too? I really have no idea how the MC is suppose to swap :S
Posted: Tue May 28, 2013 6:34 pm
by slickwill
Just about any later MC will work. It will be easier if you get a MC that is from the same bike and generation as your clutch perch so that you can order your new levers as a set. That doesn't really matter though if you are willing to just pay attention to which MC you go with and order levers individually.
I took a couple pics today. Just remove the shift lever, remove the sprocket cover, then on the backside remove the clutch cable. Once the clutch cable is free then find something to use as a spacer between the flange on the cable and the sprocket cover. Then reinstall everything. That will take out enough slack that you'll get proper adjustment at the lever.ImageImageImageImageImage
Posted: Tue May 28, 2013 9:10 pm
by architect
Thanks, Slick. The pictures help. The perch slide looks simple enough - just a matter of adding the spacer.
Do you have pics of your MC swap? Any advice on how to swap that since it seems like the more difficult one? Thanks again!
Posted: Wed May 29, 2013 9:49 pm
by slickwill
I haven't swapped mine yet but have done plenty of them in the past. It's a pretty straight forward procedure. Just do a search for brake bleeding for the proper procedure for after you do the swap.
Posted: Thu May 30, 2013 7:56 am
by Evilchicken0
Clean the cluch mechanism behind the sproket cover with some paraffin or kerasene, the old chain lube can make the action stiff.
Posted: Thu Jun 06, 2013 3:35 pm
by architect
What do you guys think about something like this?
http://www.ebay.com/itm/Universal-Fit-F ... 0e&vxp=mtr
It's the entire perch, lever, master cylinder replacement. Seems like a better deal and easier than hunting for individual used parts? Or is the OEM R6 cylinder the best?
