Pistons & rings
Pistons & rings
After reading some of the old posts about the unavailability of pistons for the FZR400, I contacted Wiseco to find out what they would charge to do a custom run of pistons. The minimum custom order is 12pcs (or 3 sets of pistons). Here is the preliminary pricing that I was provided for several quantities:
12 pcs - $156.00 / piston ($624.00/set of 4)
24 pcs - $127.00 / piston ($508.00/set of 4)
50 pcs - $106.00 / piston ($424.00/set of 4)
The price include rings, wrist pin, cir-clips. Also at these prices, they can make two different size pistons. To do this job they'll need a stock piston to measure and a bunch of money.
I don't need a new top end for my FZR, but wanted to pass this info on. If there's enough folks looking, perhaps someone with a dire need for a piston set could step up and coordinate a group buy. Here's the Wiseco contact info:
Tom Davis x3109
Wiseco Piston Inc., Technical Sales
7201 Industrial Park Blvd.
Mentor, OH. 44060
Ph: (800) 321-1364
Fx: (440) 951-6606
Posted this info in a couple of other FZR400 forums.
Tom Davis x3109
Mentor, OH. 44060
Ph: (800) 321-1364
Fx: (440) 951-6606
Re: Pistons & rings
$624 for a set? Or $156 for a set? Just wanted to clarify. Because if it is the later, lets get some for the 600's......
My FZR6 Rebuild
My FZR6 Rebuild
Re: Pistons & rings
Lol, brother, that is what I was thinking exactly!!Genesis wrote:$624 for a set? Or $156 for a set? Just wanted to clarify. Because if it is the later, lets get some for the 600's......
Re: Pistons & rings
$624 for a set. The price is per piston.Genesis wrote:$624 for a set? Or $156 for a set? Just wanted to clarify. Because if it is the later, lets get some for the 600's......
Re: Pistons & rings
Yep, that's what I figured. One could always wish thoughthatkid wrote:$624 for a set. The price is per piston.Genesis wrote:$624 for a set? Or $156 for a set? Just wanted to clarify. Because if it is the later, lets get some for the 600's......
- Level 3.5
Re: Pistons & rings
Why not do it for the 600 anyway
FZR400RR 3TJ Bimota SB6
Re: Pistons & rings
wiseco makes kits for the 600
you can find them on ebay
also, i was able to buy stock Yamaha pistons for the 600 for $48 each, $12 for the pin and like $35 for the ring kits
these were standard bore size
looked like 2nd and 3rd over sizes were available also
2012gsxr750
07gsxr750 track(gone)
91gsxr1100
1989 fzr400
400/600 in the making
91gsxr1100
1989 fzr400
- Level 3.5
Re: Pistons & rings
I wish there were Wiseco kits for them ... Maybe you can post a link ?
Re: Pistons & rings
http://www.ebay.com/itm/YAMAHA-FZR600-F ... 3e&vxp=mtrEvilchicken0 wrote:Why not do it for the 600 anyway
2012gsxr750
91gsxr1100
1989 fzr400
91gsxr1100
1989 fzr400
- Level 3.5
Re: Pistons & rings
They're 3HE .... I mean 4JH or TCat for a 3TJ hybrid
