So I have two of them but I only had one set of chain adjusters. As most of you know the chain adjusters are no longer made and trying to find a set is damn near impossible. Well, searching around I noticed the FZR 1000 use the same ones. I figured just a bigger axle hole and hopefully the angles and size were the same. The 1k adjusters can be had on ebay for about 30 shipped and are abundant. From there it just takes a press fit spacer and you are in business. In case anyone needs these or wants a spare set...
Don't know why I didn't think of this sooner. Would have been richer a lot earlier being able to sell both of them.
Nice find Nate. This would apply to the 3TJ swingers as well. In fact, I'd be curious to know what the I.D. is on the axle holes. The 3TJs have larger rear axles than the 1WG series 400s so the 1K adjusters may even be a direct / no-mod replacement for the 3TJ. Did you happen to measure before you pressed in the spacers? If so, I can grab the I.D. on the 3TJ piece to compare.
