Modern clutch perch on FZR400?
FZR400 Forum
slickwill
Post by slickwill »
I've seen a few threads on swapping out the electrical controls but has anyone swapped out the clutch perch? I'm not finding any modern levers that fit the standard perch. I'd like to run a CRG or similar. It looks like the perch from the '03-'08 R6 could possibly work but may require a custom cable?
Sent from my DROIDX using Tapatalk 2
...dude you ride an offroad bike with slicks, 1/2 the weight of a GS, double the suspension, with a browning 50 cal going off 32" from your skull as a daily freaking driver - I'd expect anything except a nitro dragbike to be bland by comparison - SSG
gsxridiot
Re: Modern clutch perch on FZR400?
Post by gsxridiot »
uh oh, i just put one of those on (07 r6)
gonna have to break out the cable to see what it will take to make it work
doing it for the same reason, some CRG's or i saw these for agood price:
https://www.motomummy.com/levers/fp-rac ... lever-set/
they look pretty good, dont know anything about them though
2012gsxr750
07gsxr750 track(gone)
91gsxr1100
1989 fzr400
400/600 in the making
willandrip
Level 7.0
Level 7.0
Post by willandrip »
I fitted GPZ 500 Z assy (circa £ 20)
Not that modern but it matched the R6 brake master cylinder upgrade lever.
I believe the ZX6r Ninja is the same.
That and new clutch cable, transforms operation.
slickwill
Post by slickwill »
The R6 perches are cheap enough that I don't think it will hurt to try. I'm sure that with a bit of ingenuity I can make it work. I did see a thread about converting to a hydraulic clutch. That's probably a bit over the top for my needs.
gsxridiot
Post by gsxridiot »
doesnt look like it is an issue,
i got a 2006 r6r clutch perch on the bay for 20 bucks
- i also went with the 2007 r6r front brake master cyl- its a brembo on that model from '06 to '09
my switch controls are in pretty good shape so i dont need to throw $ at that, but i agree it would be a nice upgrade with modern ones
2012gsxr750
91gsxr1100
1989 fzr400
slickwill
Post by slickwill »
I'll update a bit in case anyone else wants to do the same. The stock perch uses a bit more slack than the R6 perch so the R6 perch ends up very near the end of the adjustment range. To compensate I cut a small spacer from Delrin, pulled the cable at the other end, slipped the spacer between the cable and the side cover. It took out the perfect amount of slack.ImageImageImage
This will allow me to order some modern adjustable levers.
