Page 1 of 3
winter project 2012-2013
Posted: Mon Nov 05, 2012 7:57 pm
by gsxridiot
keeps me sane thru the long cold unridable winter months
well it was always 2strokes before this (RZ's, RD's and a Kawaka triple)
but i had to sell my track bike this year and figured i would need something for the track next summer
so here it is, a forgoten ex racer that has sat for nearly 15 years on its previous owners front porch waiting for somebody
its a '89 FZR400 with a '92 600 motor stuffed into it
some cool parts came with it though too: Brembo radial master, Brembo full folter rotors, Olins shock, a Marchesni front wheel and a PM rear
looks to have been repaired with a hammer
this ones gonna be alot of work
Re: winter project 2012-2013
Posted: Mon Nov 05, 2012 7:58 pm
by gsxridiot
this is going to be alota work
Posted: Mon Nov 05, 2012 8:00 pm
by gsxridiot
sourced a complete subframe
before:
after:
Posted: Mon Nov 05, 2012 8:02 pm
by gsxridiot
sanded off the old clearcoat on a '90 swing arm - what a PITA!
cleaned up most of the blemishes and re-clearcoated it
what do you think?
Posted: Mon Nov 05, 2012 10:07 pm
by GreyImport
looking great....
What procedure did u use with the subframe ?
Posted: Tue Nov 06, 2012 8:12 am
by gsxridiot
GreyImport wrote:looking great....
thanks alot,
procedure i used: about 8-10 sheets of 150 grit sandpaper- worked the bad spots out and used the factory paint as primer(just scuffed up existing finish) and painted with my favorite rattle-bomb
used same brand rattle-bomb clear on the swingarm too
Posted: Tue Nov 06, 2012 12:31 pm
by fzrbrandon
Dude! That swingarm is gorgeous! Nice job!
What grit did you use? The brushing turned out great.
On the other hand, that tank looks hideous. I'm sure it can be cleaned with A LOT of elbow grease. However, if you don't feel like going through the hassle, I've got a fairly nice one for sale if you're interested. $30 + shipping (including a cap and key).
Posted: Tue Nov 06, 2012 9:41 pm
by GreyImport
gsxridiot wrote:GreyImport wrote:looking great....
thanks alot,
They both really did come up well.....
the 400 subframe is so much more "smooth and flowing" than the 250.......i think ill need 50 sheets of paper and 10 tubs of elbow grease.....so many bits and pieces and hard to get at spots.
This is after a hit of paint stripper....did pretty much zero
Posted: Tue Nov 06, 2012 10:49 pm
by gsxridiot
i know, Grey
that factory finish is tough, i tried multiple chem strippers with no sucess, even that "aircraft stripper"
i have had good luck just using the factory finish as a primer to sand on
that stuff is no doubt tougher than any product i can spray in my garage- so be it, i'll use it
one day i will own a proper blast /media cabinet, till then its stinkin sandpaper
Posted: Thu Nov 08, 2012 12:20 am
by GreyImport
Yea I think Id wish for a "parts cleaner" ! .....even a dishwasher to sneak a few things into...
But Ive cheated with my subframe today.....I went to the local powdercoater just to see how much to "sandblast" it ...... $AU40 ... and it was only an xtra $20 to coat it so I said
call me when its ready!
Posted: Thu Nov 08, 2012 12:33 am
by HybridSport600
I agree with GreyImport, that swinger looks sexy as hell man!!! Great job.. Im curious to see what your thinking about doing with the inside of that tank?
"Got a $5 head, get a $5 helmet"
Posted: Thu Nov 08, 2012 5:03 am
by gsxridiot
fzrbrandon wrote:Dude! That swingarm is gorgeous! Nice job!
thanks Brandon, again that was 150 grit sandpaper on the swingarm too
heh, that gastank is classic! didnt even smell like gas at all 100% varnish
i have another one that is in much better shape that i will be using
allthough it would be interesting to see what it would take to rehab this one, possibly a few pounds of nuts and bolts, a bbq rotisserie and a few days spinning would be a good start
then do the battery charger electrolisis
- glad i have a spare one
Posted: Thu Nov 08, 2012 12:23 pm
by thatkid
You can use phosphate etch from home depot or The Works toilet bowl cleaner. Both do a pretty good job with rust removal. Otherwise I have two powder coated tanks that are rust free.
Haven't forgotten about your PM either. Trying to get pictures to my comp is proving difficult after the last system update screwed some things up.
Posted: Thu Nov 08, 2012 4:48 pm
by HybridSport600
gsxridiot wrote:fzrbrandon wrote:Dude! That swingarm is gorgeous! Nice job!
We use muratic acid "slightly" diluted for about 4hrs in 2hrs out, and repeat till clean metal, then creme the inside befor it starts to turn....Im glad you have a spare one too....
Posted: Sun Dec 02, 2012 6:51 pm
by kirbster
Nice job on the subframe, it looks amazing. What brand and colour did you use and did you prime it as well?
Thanks.
