fzr 400 3en2 big question
FZR400 Forum
fzrowner1
Post by fzrowner1 »
does anyone know if the fzr 400 3en2 is the same as any others like 3tj or anything like engine and i really wana know if any other downpipes will fit it thankyou
S.J.Hunter
Yamaha FZR400R 3EN2 1989
taggy
Level 1.5
Level 1.5
Re: fzr 400 3en2 big question need help please
Post by taggy »
3en1 and 3en2 should be fine. 3tj will be different, think it's to do with the spacing between ports being different. you can use fzr 600 pipes but they hang lower and need the fairing spacing out. 3tj are probably just as difficult to get hold of! if you want to do some fab. you can adapt r6 ones, or shorten the 600 youll lose the exup on the r6, not sure about 600.
Fzr400 3tj x2
'94 cbr 900rr
willandrip
Level 7.0
Level 7.0
Post by willandrip »
3en series 1 & 2 interchangeable as is 2TK sp(rare)
1WG Genesis fit but no exup valve fitted (recommended retained on the 400 as they lack bottom end torque anyhow)
3 tj series and 4 dx different engine configuration (angle of mount at least is different.more canted) not recommended.
Some have had success with 600 pipes but require fabrication mods.
Presume downpipes shot ????
Not finacially viable to repair unless you are an expert welding technician.
Recommend used 3EN series =less than £100 a bargain in todays market,
Bill.
fzrowner1
Post by fzrowner1 »
i have a very good engeneer friend (builds bikes) so im getting at as much help as poss off him he has a friend who bends pipes and he said he could get them made for around 150ish? and my servo is not attached never has been does it make it alot different? cheers and can i just jam it open on exhaust end?? cheers
S.J.Hunter
willandrip
Level 7.0
Level 7.0
I think a new set of stainless pipes are only £199-hardly worth trying to make a set to save £49 .(No valve fitted.)
If you have never had valve operational you would not miss it !!
In what position is the valve now ??
Earlier models had no exup valve , it just aids torque at lower rpm.
It will probably be siezed in mid or closed position by now,the exhaust gasses have not the flow to keep it in the fully open position !!
fzrowner1
Post by fzrowner1 »
im not sure how do you tell what position it is in? cheers
S.J.Hunter
fzrowner1
Post by fzrowner1 »
dont suppose you know what exhaust gaskets i need do you what size?
S.J.Hunter
willandrip
Level 7.0
Level 7.0
This is what you get for £ 150
http://www.ebay.co.uk/itm/Yamaha-FZR400 ... 19d699fc10.
They will not fit but are shown as an example of what £150 gets you !!!
This latest question will have been answered on here about 20 times i would imagine =try a search.
fzrowner1
Post by fzrowner1 »
i find allsorts for all other fzrs i cant find downpipes or nothjing for the 3en2 :s
S.J.Hunter
