Greetings all,
I just bought a fairly well beat '88 FZR400. Doesn't look like anyone has treated it well until now. I've spent the last couple of days going through the electrical & trying to get the bike to start. I was successful today & the bike finally started. While working on the bike & getting to know it. I discovered that not only was the rear wheel changed to a 17" wheel, the swingarm was exchanged for a steel swingarm. Not a good swap in my opinion. My rear wheel doesn't match the front wheel due to the 3-spokes being angled differently.
What are the chances of locating & buying an original aluminum FZR400 swingarm in the US? How much should I be prepared to pay for one?
What would be the next best swingarm to use in place of an original? I would like to be close to matching the original swingarms dimensions & weight or lighter.
What seems to be the easiest or best set of matching 17" wheels to use? What is involved with the swap & how much should I be prepared to pay for a set of wheels? I would like to use the lightest weight wheels as possible & I'm not interested in trying to stuff the widest tire that I can under the bike.
I would prefer to keep the bike all Yamaha if possible. Unless there is a substantial weight savings or performance improvement to be had using another manufacturers part.
My intensions are to build the bike as light as reasonably possible & to attempt to swap an RD400 engine into it. I selected the FZR400 as an ideal swap candidate due to its overall size & weight. Not to mention its reputation as an excellent handling bike. I don't plan on upgrading to the more modern upside down forks or bigger brakes, etc. The bike should weigh much less with the air cooled RD engine & should be easier for the suspension & brakes to control.
My back up plan in case the RD400 engine swap doesn't work out as well as I would like, is to build a FZR400/600 hybrid.
Thank you
~JM~
Info Needed On FZR400 Swingarm & Wheel Options
Re: Info Needed On FZR400 Swingarm & Wheel Options
If someone has already gone to the trouble to fit a 17" wheel to your FZR400, the wheel and chain line up ok and it looks reasonable - then I'd leave it in! There is alot of machining required to make most other wheels fit - not saying it can't be done at all though. TZR250 rears, SZR660 rears, possibly TRX850 and 1990 on FZR400RR SP rears are a few that might be woth a look. As for non Yam then mid 90's GSXR750's and I'm sure someone mentioned a CBR or Honda hornet wheel. I suppose it depends on how much you really want it and how much time/$$$$ or both you are willing to throw at it. Thinking about it maybe you have a YZF600 swinger/wheel (FZR600 'foxeye' here in the UK)
Like all good projects......
Hope it all goes well
Chris
Chris
3x RG80 Gamma
3x RG80 Gamma
If you could supply some pics and dimensions, I could possibly trade you. I have a couple of the originals here.
1990 FZR400 with some mods
- Level 4.0
Does anyone have any 05/06 ZX6R wheels kicking around? Rumour has it with slight persuasion they can be made to fit a stock FZR swingarm.
Pity I cut up two and scrapped them.....No interest on Ebay. I do have a good rim with brand new tire mounted..
Best luck! Neil
Best luck! Neil
I do..... I may try them out on my project bike (an XR650R motor in an FZR400 chassis) I'll post the results of the wheel swap.Freestyle72 wrote:Does anyone have any 05/06 ZX6R wheels kicking around? Rumour has it with slight persuasion they can be made to fit a stock FZR swingarm.
XR650R in an FZR400 chassis project
You should post up a build thread. That way we get pics of how close the wheel/swingarm is and I get to see a supermono fzr like I have been thinking of for my extra frame.tgold wrote:I do..... I may try them out on my project bike (an XR650R motor in an FZR400 chassis) I'll post the results of the wheel swap.Freestyle72 wrote:Does anyone have any 05/06 ZX6R wheels kicking around? Rumour has it with slight persuasion they can be made to fit a stock FZR swingarm.
cb175 cafe sitting in storage
88 fzr4/6, only the frame is stock
