How to identify my model
FZR400 Forum
fzrbrandon
Level 7.5
Level 7.5
Re: How to identify my model
Post by fzrbrandon »
Okay, that's what I thought. As I mentioned earlier, there's nothing for the 400 rotors. I'm trying confirm numbers so we can get them added to the list.
Image Image
http://www.fzrbrandon.com
Fzrmike33
Post by Fzrmike33 »
Anybody know what front rotors from other bikes will fit a 90 400 1wg ????????/
dru86
Level 1.5
Level 1.5
Post by dru86 »
cad600 wrote:Brandon,
The 2TK was kind of like the FZR400RR (pre SP days) with the single seat and adding the small adjustable items.
The 2tk is actually known as the 400RSP. When the 3en2 came out it was the 400R and the 3tj was the 400RR, it was the single seat version of the 3tj(with other mods) that was the 400RRSP.
The major change with the 3en series frames is that the rear shock mount is now part of the main frame, not the subframe as it was on the earlier 1wg's. This made the bike more rigid and also makes it a hell of alot easier to make a custom subframe :thumbsup: .
