There's a 3TJ swingarm on your americaland ebay ... http://www.ebay.com/itm/FZR-400-RR-SP-A ... dd&vxp=mtr
Might help
It looks ex-race with no chain guard mount and no chain slipper on the arm
17 inch rear wheel swap in a fzr400-600?
Evilchicken0
- Level 3.5
Re: 17 inch rear wheel swap in a fzr400-600?
FZR400RR 3TJ Bimota SB6
Thanks for the tip Evil....I picked it up for my project bikeEvilchicken0 wrote:There's a 3TJ swingarm on your americaland ebay ... http://www.ebay.com/itm/FZR-400-RR-SP-A ... dd&vxp=mtr
Might help
XR650R in an FZR400 chassis project
Evilchicken0
- Level 3.5
What's a swingarm spool ?
Evilchicken0
- Level 3.5
They're standard on the SP swingarm, the SP also has captive wheel spacers and quick change wheels. The SP arms have a ridge that the spacers sit on for more easy wheel changing.
The RR doesn't have the threads for swingarm "bobbins"
I'll probably drill & tap for "bobbins" just aft of where the machined section is welded to the swingarm.
As for the captive spacers and guides, I made my own set for the current swingarm, so I should be able to use them on the "new" swingarm.
