I have a 3TJ swingarm and rear wheel on my 1WG, as well. It is a great set-up. Particularly if you are running a T-cat motor, as the sprocket offset is very close. It you are not using the T-cat motor then you well need to space the front sprocket out. (6mm?).YPM25 wrote: Should save a fair bit of money using these disks and the wheel will match the rear 3tj wheel i will be using. Win
Not sure how the wheel will fit yet as i havent seen the parts yet.
R6 Forks 3TJ Wheel
Re: R6 Forks 3TJ Wheel
I have a 3TJ and a 1WG. I have done this set-up on a 1WG but not a 600. I have a friend with a '1WG and a '92 FZR600, and from what I can tell the fork length is about the same between the two but the 600 stands taller, so I'm sure that if 3TJ forks are too short for a 1WG, they will be too short on a 600. I'm not saying that it can't be done. I'm just sayin' your front ride height and bar placement will be lower than original. I'll take some measurements this weekend to make sure.mawler wrote: I have a 92 FZR600 does that still apply. Thanks.
mawler wrote: I've located a set of upside down FZR400 3TJ forks.
Show me that bike, so I can swap forks without getting protested.
Bummer. Let me know how it goes.mawler wrote:NO photo just a link to buy a set.
I've got some measuring done, so you can assess the 3TJ fork option.
Fork length (from spindle to top of tube)
FZR600: 795mm
FZR400RRSP (3TJ): 710mm.
Here is a pic of my 3TJ front-end.
Notice the step in the triple clamp to accommodate the shorter forks. Normally the tops of the forks are flush with the top of the triple clamp, and the clip-ons mount below. Because of this triple clamp design, mounting to a 600 would require much lower bar placement than original. It's doable, and not bad for a track bike, but it is aggressive for street riding.
I also took measurements for ride height by measuring from the axle to the bottom of the lower triple with the forks fully extended. Measurements are given with the forks flush with the clip-ons for the 600 and 1WG, and flush with the upper triple on the 3TJ.
FZR600: 490mm
FZR400(1WG): 475mm
FZR400RRSP (3TJ): 465mm
As you can see, running a 3TJ front end will result in 25mm less front ride height. You might be able to get away with it. I actually run 465mm on my 1WG, but that's only 10mm less than stock. It's 25mm for the 600. That is a big difference. I have no idea how the 600 would take it.
FZR600: 795mm
FZR600: 490mm
FZR400(1WG): 475mm
With the R6 forks (40mm shorter than fzr((still not got them to comfirm))) and the 3tj triples as shown in the pic above,
I was hoping that would still be able to maintain stock ride height and keep the clipons above the top clamp. The gul wing shape should help.
I'm assuming your going with first generation ('99-'02) R6 forks. Those are longer than the later ones. It's been a couple of years since I had the R6 forks in that set-up on the 1WG. I had the clip-ons below the triple clamp, but as I recall there was just enough fork length to mount the clip-ons on top. Again that was on a 400, not 600. I had stock springs in those forks which are really soft, so I'm sure you would do better and gain some ride height with stiffer springs.
I did later state there was no photo, I messaged the seller. Today he uploaded a photo and edited the description, they are conventional forks. Plankmawler wrote:I've located a set of upside down FZR400 3TJ forks.
Thanks to RoadDogma's brilliant advice the 400RR front end is not for me. Thanks.
The 3en2 did in fact come with 41mm forks. As said previously pre that came with 38mm (3en1, 2tk and the earlier 1wgs) and post that (3tj/4dx) had 43mm.RoadDogma wrote: Be careful. Much of that info is in error.
None of the FZR400s were fitted with 41mm forks. The T-cats got 41mm not 43mm, and only the '89-'90 FZR1000 had 43mm.
Sorry, one of the 400 models had 41s. I'd still be careful, that's only one of the four "FZR400s before 3TJ" that will accept T-cat forks, so make sure it's a 3EN2, and good luck trying to fit T-cat forks into 43mm FZR1K triple. T-cats only came with 41mm forks.
Put together all the parts loosely last night, 3tj front and rear wheels, 3tj swingarm and yokes and R6 forks. Looks like it will end up being very agressive geometry. It all sits lower than standard, swingarm is shorter. So it looks like the rear will have to be raised alot making the steering steeper
Few spacers to make now. Really want to clipons over the top yoke but this looks like its not going to allow enough ground clearance with the forks pushed that far through.
Might start a new thread the correct section as this is a 600
Mounting the clipons aove the tripple clamps instead of below will only effectively give you the height of the top tripple clamp anyway. However will change where the forks sit through the triple clamps the thickness of the clipons.
When i had my early r6 front end on the 600 I had the clipons mounted underneath the top triple and really liked how it rode. I think with the clipons mounted on top (aftermarket clipons about ~30mm thick) the bike would have been too twitchy.
