Hi, thanks alot for the tip, not used Plastex, just Q-Bond.
I've used the welding technique many times before and im pretty comfortable with it, my personal experience with Q-bond is it does indeed work well for clean break cracks, but when there are chunks completely missing (like I have) the abs welding works very well for me and as long as you dont over/under heat it its very strong, I've never had a crack come back or a piece break off. Some bits that I repaired on the weekend are curved sections of ABS that had to be heat bent to shape and welded in.
For the fiberglass Solo Seat, the repairs will be done with a product called Polyall 2000, much better than fiberglass resin for making secondary repairs. Amazing stuff
the botton corner of this mid fairing was missing:
top of this duct (where its black) was completely gone, welded in new abs and sanded it:
of course, all the repairs will be sanded smooth and any imperfections will be treated with surface filler before priming
Fiberglass repair ...I grind away the gelcoat where ever there is spider cracking (see pic) the Polyall is applied in 2 ways 1) with cloth/mat on the back side to re-enfore the weak area, and 2) in the spider crack on the top side to penetrate the fissures. Polyall is the same viscosity as water when first mixed so it penetrates the old fiberglass parts very very well (where resin just cant due to thickness). Polyall also stets up in 10-15 minutes to the point ou can use a grinder or sander on it. It can also be used to pour into a mould to fabricate missing parts. Ive been using this stuff for over 10 years on my snowmobile restorations and wont use anything else for fiberglass.
