Hard to Start and Runs Rough in Rain
My FZR400 is hard to start and runs rough in rain. I am not real experienced in troubleshooting but I am going to take it apart to have a look, any specific problem spots I should look for? Any advice would help.
Mayhew
PEI, Canada
1989 FZR400
PEI, Canada
1989 FZR400
- Level 3.5
Re: Hard to Start and Runs Rough in Rain
Have a look at the plug caps and leads. Make sure they're on tight if they're loose screw them back in and see if that helps. If they're still lose take the cap off cut the ht lead back 10mm then rescrew the cap on.
Could also be a dodgy elec connector ...
Have a look for one that's broken or discoloured. Use a little wd40 open and clean it then put a light smear of vasaline on the male and put it back together.
FZR400RR 3TJ Bimota SB6
