Set of R6 headers on the FZR400/600
FZR400 Forum
buzzawak
Level 2.0
Level 2.0
Post by buzzawak »
My version of R6 headers on the FZR400/600. decided to retain the cross pipe between cylinders 2 & 3.
Still need to do the rear mount and may end-up raising the oil cooler a bit
Just took the bike for a run to test out the R6 headers. Most noticeable difference is how well it pulled after 8k and kept pulling hard right up to red line. :banana:
With the old header it would flatten out after 9K
loganlexow
Re: Set of R6 headers on the FZR400/600
Post by loganlexow »
How are you bending the tubes to fit? I have been incredibly curious about this but I can't wrap my head around the immense difficulty that is bending lol
Sent from my HTC Desire Z using Tapatalk
1990 FZR400 with a Kerker exhaust for now. In the process of fork swap, shock swap, and 17" rear wheel
SouthendChris
Level 2.0
Level 2.0
Post by SouthendChris »
I take yours is a 1WG FZR400 ????
What model/year R6 did the new headers come from ???
Very curios as I am looking at putting R6 headers on my 3TJ bike eventually.
Chris
1990 3LN3 FZR250 - back in safe hands :)
3x RG80 Gamma :)
buzzawak
Level 2.0
Level 2.0
Post by buzzawak »
My bike is a 1WG FZR400 frame with fzr600 engine, the headers are from a 2004 R6. Cost me $100 inc postage and were in great condition.
You can buy a set of modified R6 headers from "thatkid" for $130 US but because I live in Australia, the postage would have been more than the headers.
All I did was to cut the cross pipe between cylinders 2 and 3 then made up a jig (length of 1-1/2" square pipe) to hold the 4 pipes parallel.
Used a expanding screw thread between the pipe for cyl 2 and 3 to spread them while heating up the pipe just before the final join.
Once I got the right gap between cyl 2 & 3, welded in a piece of matching pipe to rejoin the cross pipe.
The gap between pipes 1 & 2 and 3&4 need to be increased also but its only about 3mm so I just forced them in-place when installing the headers on the bike.
One interesting thing I found is that the headers are zinc plated steel. Zinc can be polished to near chrome finish. This I did but you have to be careful as I would assume
the plating isn't that thick. I ended up putting on a clear flameproof coating just in-case I over did it with the polishing. I left a hidden section of the pipe uncoated and if it stayed
rust free I will end-up removing the clear coat.
Another thing to remember is that the R6 headers end about 2" shorter and a bit larger that the original headers so you need an extension pipe with one end reduced if you are going to use the original can.
