As topic says, im looking @ these 1992 YAMAHA FZR400 3TJ PILLION PEGS, I.E. are the hanger to frame mounting holes the same measurement eye to eye? I can adjust the end can bracket to accommodate the right hanger with no problem.
I'm looking to swap my pillion pegs to some nice alloy one's so I can polish/improve the appearance, without any modifications to the rear subframe.
Mal.
Anyone know if FZR400 alloy pillion hangers/pegs fit FZR600?
Re: Anyone know if FZR400 alloy pillion hangers/pegs fit FZR600?
Mal,mawler wrote:As topic says, im looking @ these 1992 YAMAHA FZR400 3TJ PILLION PEGS, I.E. are the hanger to frame mounting holes the same measurement eye to eye? I can adjust the end can bracket to accommodate the right hanger with no problem.
Mal.
It may be an "urban myth" that there is a model of 400 that fits the 600. I have two sets sitting idle that DO NOT fit
a 1wg & 3tn (Allegedly ) they look the same as each other (odd in my mind) I figure someone selling knew Jack about the model & palmed them at a fiver approx a set what the hell.
I could ask about the mounting hole distance IF I knew it :-} on a racer boy 400 list in europe.
Spacing for the 3TJ hanger mounts is 60mm. 1WG spacing is 75mm-80mm. (Looks like 78mm)
If the holes don't align, I'm sure you could fabricate some kind of adapter.
thatkid
Thanks for that, I'd just noticed a cheap set and Ebay. I've just measured mine they are approx 105mm, I'll give them a miss. I've also considered grinding the mount off the subframe, then grabbing some later R6 one's the type that hang below the subframe rail, and bolt in from the top. I want things to look tidy.
Thanks again.
Thanks again.
