generator cover
FZR400 Forum
turgzie
generator cover
Post by turgzie »
hi does anyone know if a fzr600 generator cover will fit a fzr400?
bendy3
Re: generator cover
Post by bendy3 »
Should do.
DonTZ125
Moderator
Re: generator cover
Post by DonTZ125 »
Depends on the year of the 400. Some mount the stator on the crankcase under the rotor, some mount the stator in the cover itself. The styles don't mix & match.
dru86
Level 1.5
Level 1.5
Re: generator cover
Post by dru86 »
I'm pretty sure you can use a fzr600 cover on a fzr400 as the 400 stator is not attached to the cover, however you can't use a fzr400 cover on a fzr600. This applies to the non 3tj models of fzr400, the 3tj ones you may be able to use on a 600.
