Carbi Jetting
FZR400 Forum
buzzawak
Level 2.0
Level 2.0
Carbi Jetting
Post by buzzawak »
Question: wondering the performance (or ridability) difference between using the same size main jet in all 4 carbies compared to having the outside two carbies jetted different to the inside two?
Dragon
Level 2.5
Level 2.5
Re: Carbi Jetting
Post by Dragon »
Not doable!!
You have to have the same size jets on all carbs...
Re: Carbi Jetting
Post by sweekster »
Dragon wrote:Not doable!!
Not true..for example...the FZR 1k comes stock this way (I'm running FP Stage 1 which is 130 on the outters and 127.5 on the inners-Stock is 122.5 and 125 if I recall). The theory from what I have read is it helps with cooling and my bike runs great. I don't think it's a needed setup on the 600 though. But I'm just guessing.
Dragon
Level 2.5
Level 2.5
Re: Carbi Jetting
Post by Dragon »
Hmmm, first I have heard of this.... I may be wrong. :headscratch:
YG/ Razor/ anyone you got any input on this?
Re: Carbi Jetting
The carbs do not need to be copies of each other at all,
Due to manufacturing tolerences accomulating each cylinder is an individual as is the pipe from it.we are talking valve opening times / sizes of pillows rounf the valve aslight varience in the duct passed the valve Ad Nausium.
Bearing in mind it stands to reason jettiing CAN be off fro one cylinder to another. Anyone who has synched a bunch of four carbs will tell you that they can vary wildly as can compressions across heads .
Yamaha will "best guess" on the rich side & use blah heat plugs to keep the engine together for warranty after that you are on your own "said very politely with an inscewtable smile ".
mossy1200
Level 5.0
Level 5.0
Re: Carbi Jetting
Post by mossy1200 »
I always thought that the inners should be bigger if your going to mismatch as the inside cylinders run hotter so running them richer helps even the temps.
