3en2 coming to a year long end
Sent from my SM-N9005 using Tapatalk
Re: 3en2 coming to a year long end
Just a few picks..... thought I had a barging at £500..... nothing worked.... valves and piston rings were shot.... never seen anyone try and repair electrics like that before. List goes on and on. But hopefully it will be finished and MOTed next week. Partner takes her test next week, so hopefully I can hand the keys over
The black bike pics ( aerosol at that!!!) Is it's original state... you just can't see how bad it was.
- Level 3.5
I know the feeling when you look at it and what the actual f'king hell is that ?!!?!
during the build
during the build
FZR400RR 3TJ Bimota SB6
Looks like salt from the roads...allweather-driver which had driven in winter?Evilchicken0 wrote:I know the feeling when you look at it and what the actual f'king hell is that ?!!?!
Stucked Drain/Wateroverflow hole ...never properly cleaned due to the fairing (="no need to clean when noone could see" or similar stupid thoughts![]()
Oh, definitely better cleaned then...during the build
Wow that looked bad. Love the use of instant gasket.... I hope my next project goes a little smoother than this one.
- Level 3.5
It was liquid metal, I guess it was to try and seal the pipes, but the real problem was where a stud had broken part of the head. I used a piece of threaded bar and an exhaust nut to hold it onto the head.TomcatMJ wrote:
Stucked Drain/Wateroverflow hole ...never properly cleaned due to the fairing (="no need to clean when noone could see" or similar stupid thoughts)...
Yeah that hole was a real headache, I tried to drill it but the alloy had corroded into it and I could feel the bit moving to one side. I used a hand tool and penetrating oil to chip it out .... 2 hours.
Lots of cleaning, between my friend and I we made up a rough bodykit then repaired it with Plastex'd and resprayed using aerosols
