Anyone no where to get this in the UK .... need it to seal crankcases .
cheers
Yamabond ?
Re: Yamabond ?
If noone knows, try this: http://shop.diamant-polymer.de/produkte ... uster.html
i used the higher-polishable Version http://shop.diamant-polymer.de/produkte ... uster.html for restauration of 2 Alternator-Covers and it works well, but the first linked version bears higher temperatures which might be neccesary for the crankcase
OK, its not a shop located in UK but in Germany...but shipment isn't so expensive to the UK as from the US or Japan
Evilchicken0
- Level 3.5
Re: Yamabond ?
You can use Three Bond and get it off ebay, http://www.ebay.co.uk/itm/Threebond-110 ... SwqYBWpzqP
Otherwise try Demon Tweeks or if only Yamabond will do .... your local Yamaha garage
FZR400RR 3TJ Bimota SB6
Re: Yamabond ?
AH,seems i missunderstood the search a bit as most products including "bond" or "bonding" here in germany are a kind of mix between glue and an alternative to epoxy, not used as a sealent like Dirko HT or Hylomar, which are both the brands mostyl used for cylinderhead-gasket support or valvecover-gasket support here in germany
