![BONK bonkonhead](./images/smilies/iconbonkonhead.gif)
ninja 636 shift problems
i have an 02 ninja 636. here is the problem, when i came into posesion onthe bike it wasnt upshifting everytime i tryed to. the peg would lift up but there would be no gear change. hmmm... so i checked the oil and yep it was low. so i added oil and it was working perfectly fine. would only do it once in a while. well i tookthe girlfreind out on a ride today and the damn thing wouldnt downshift at all. i got stuck in 5th gear and luckly got it to start shiftin again and got it home. would this be internal transmission related or is it something under the front sproket cover? feels like there is to much distance between parts inside ther. haha yes i know this isnt a ninja forum ![BONK bonkonhead](./images/smilies/iconbonkonhead.gif)
Re: ninja 636 shift problems
Have you tried adjusting the clutch lever? Make sure that the clutch is engaging properly.
Hopefully it's a clutch issue and not a transmission issue. Could be shift forks or shift drum, but I would start with looking at the clutch.
Would the bike try and lunge forward if it was a misadjusted clutch? Bike isn't showing any clutch symptoms but damn right I'll check it out I ain't gonna skip the easy stuff! Thanks
Certainly. Also could be an incorrectly installed clutch cover.apsolus wrote:Would the bike try and lunge forward if it was a misadjusted clutch?
a lot of that going around,ragedigital wrote:Certainly. Also could be an incorrectly installed clutch cover.apsolus wrote:Would the bike try and lunge forward if it was a misadjusted clutch?
![Laugh Out Loud lol](./images/smilies/lol2.gif)
no none of that is to blame. listen to this, after inspecting under the sproket cover i noticed there wasnt anything there to adjust, just the rod entering the engine case. so after doing some inspections of all the related stuff i took it for a testride. upshifted beautifully. now downshifting wasnt working. i found a little trick to make it down shiftagain. from lets say 6ht gear i would push the lever down, into 5th, then i would liftup slightly on the lever to bring it back up to the middle rest position, then back down to complete the downshift, you follow? and i would repeat that all the way to first. also while down shifting to a stop im sure all of you notice when your bike hits 1st gear the lever doesnt go down all the way like it does for the rest of the gears. well mine just continues to fall into that downshift zone. so i belive my trans is fine but there is something in the linkage that came apart or is broke. any one ever experience this? or havetorn into a trans and can guess at what componentwould cause this?
missing a spring maybe??
SOLD
SOLD
i got some pics i wanna add. but dont know how to add to the message, help please
viewtopic.php?f=8&t=521apsolus wrote:i got some pics i wanna add. but dont know how to add to the message, help please
hahaha i tryed but its getting close to bed time i cant spend all night figuring out how to post a pic! but i did get as far as posting and making my own album maybe you can go check out the pics there
EDIT:: Photos added (rage)
![Image](http://fzronline.com/gallery2/main.php?g2_view=core.DownloadItem&g2_itemId=20008&width=150&height=113)
![Image](http://fzronline.com/gallery2/main.php?g2_view=core.DownloadItem&g2_itemId=20012&width=150&height=113)
I don't see anything out of the ordinary...
i had no idea what i was looking at but it all lookedright. ohwel guess i gotta start tearing into it
there was never anythin g wrong with it. shift lever pivot was just gummed up and needed some lube. no buddy talk shit cause it aint my bike and just started happening suddenly! we tend to ignore the obvious. dont forget the lube boys ![DUH :duh:](./images/smilies/35.gif)
- kilika2
- 1000+ Posts
I don't think any of us has any reason to do that, we have all missed something obvious. Me expecially. Glad everything is working great now.apsolus wrote:no buddy talk shit
Chris.
1995 FZR600 Sold
![Sad :-(](./images/smilies/icon_e_sad.gif)
2006 R1 Sold :-\
2009 Buell 1125R
![Smile :-)](./images/smilies/icon_e_smile.gif)
Sounds like you came from the GIXXER.com forums...apsolus wrote:no buddy talk shit cause it aint my bike
