![Image](http://i295.photobucket.com/albums/mm143/PIMPMYFZR/r1lights.jpg)
,a retrofit projector kit H4,
![Image](http://i295.photobucket.com/albums/mm143/PIMPMYFZR/4e0e_12.jpg)
![Image](http://i295.photobucket.com/albums/mm143/PIMPMYFZR/4ddf_1_b.jpg)
and some led' strips <2>
![Image](http://i295.photobucket.com/albums/mm143/PIMPMYFZR/packagethumb.jpg)
that are supposed to look somwhat like New style audi Daytime Running Lights .
![Image](http://i295.photobucket.com/albums/mm143/PIMPMYFZR/AudiR8.jpg)
Well i set the oven to about 225 and let it preheat .
Took the headlight housing and threw them in there <on top of some oven mits>
pulled them out after bout 8-10 minutes and pried the glass lense cover from the rest of the housing .. Took the chrome plastic looking reflector primed it then sprayed it black threw them in the oven for about 15 minutes on low ..
Then i took the led strips and lined them across the lense part with some high temp clear silicone .. got kinda messy but cleaned up ok .
finally mounted the reflectors back up and installed the projectors right into the whole like plug and play sorta. ran the wire for the led throug the housing , put the headlight sort of back together but not locked in . threw the whole thing back in the oven for about 10 minutes and pulled them out and sealed it back up .. and this is what i came out with from stock to these
before
after
![Image](http://i295.photobucket.com/albums/mm143/PIMPMYFZR/IMG_1397.jpg)
![Image](http://i295.photobucket.com/albums/mm143/PIMPMYFZR/IMG_1398.jpg)
with the led lights on
![Image](http://i295.photobucket.com/albums/mm143/PIMPMYFZR/IMG_1404.jpg)
![Image](http://i295.photobucket.com/albums/mm143/PIMPMYFZR/IMG_1408.jpg)
with one angel eye also
![Image](http://i295.photobucket.com/albums/mm143/PIMPMYFZR/IMG_1410.jpg)
BTW these projectors come fitted with angel eyes <color choice is urs > i chose white because i like to have it all white .
And the headlight are BI-Xenon Both hi and low are xenons but im still working on that .. But so far thats where i've come up to still tryin to figure out where im going to hide all these wires and actually mount the headlights and get everything situated as id like to have switch for led's and switch for angel eyes and switch to cut of headlights and run these when i feel like .. but i Need a day off so i can rest and acually have energy .. Alsoi did this while i was working in back of my restaurant with no special tools and a spare oven we use in the back hehe .. so my next one will looks more profesionall ..
So whatcha guys think , not bad for a tool working out the back of a restaurant ..if i only had my own shop hehe
