swing arm dimensions
can anyone tell me the distance from the pivot to the axle and the width of the pivot of a 99-02 R6 swinger?
Re: swing arm dimensions
did you check the wiki theres the 99 02 swap in there and the 0305 is floating around as well i did the 03 05 and i wound up needing a final length of 9 and 3/8 but i think it starts off at around 10in
im trying to see if a r1 swinger from the same year is the same size
lrc131 wrote:can anyone tell me the distance from the pivot to the axle and the width of the pivot of a 99-02 R6 swinger?
hi,
This is a VERY COMMON swap and has been well covered in the FORUM, so SEARCH is your pal here.
It is also written up in the WIKI as a HOW-to:-
Please put your location in your details
If you are in Timbuctu some one in New Zealand cannot recommend a source of parts etc.
read the post above yours...
the wikis dont give the info i need
