FZR600R tickover/ over rev when hot
can anyone tell me whats happening to my tickover? : when the bike is hot (been running for a few mins) when i shut the throttle i get high revs about 2k for a couple of secs before it drops to 900rpm haven got the first idea where to start with this one many thanks
FZR600R '94'
Bluespot calipers
Wavey front discs
R6 front mastercylnder
Mild steel chain adjusters
Art can with removable baffle
Carbon fiber chain guard
Glass fiber rear seat-hump
Bluespot calipers
Wavey front discs
Re: FZR600R tickover/ over rev when hot
I would look for any air leaks, split inlets etc. 900rpm is too low as well, idle should be 1200/1300rpm.
John
John
1994 FZR600R
Get this sorted before you go back out on the bike - a bike that won't rev down will quite cheerfully pull you into cross-traffic!
Hi John no I haven't fixed it yet but I have found out what it is and I have got to remove the carbs and strip them down to fix it so it's a job for end of season as it's only over revving for a second or so and only 400ish rpm high it will be fine til oct.
FZR600R '94'
Bluespot calipers
Wavey front discs
Bluespot calipers
Wavey front discs
What is the problem?dougs wrote:Hi John no I haven't fixed it yet but I have found out what it is and I have got to remove the carbs and strip them down to fix it so it's a job for end of season as it's only over revving for a second or so and only 400ish rpm high it will be fine til oct.
1994 FZR600R
Basically the carbs and linkages are gummed up and need stripping down, cleaning and relubricating nothing serious just a bit of a 'take your time' job
FZR600R '94'
Bluespot calipers
Wavey front discs
Bluespot calipers
Wavey front discs
