Foxeye Rotor Help needed
I have got to replace my front rotors (discs) are the fzr600r discs compatible with anything else? the newer yzf600 discs are bigger and mount differently
i have looked at the wiki and the foxeye 94/95 is not shown can anyone help?
FZR600R '94'
Bluespot calipers
Wavey front discs
R6 front mastercylnder
Mild steel chain adjusters
Art can with removable baffle
Carbon fiber chain guard
Glass fiber rear seat-hump
Bluespot calipers
Wavey front discs
Re: Foxeye Rotor Help needed
This will sound strange but the rotors are the same as what was used on the pre fox eye 89-93 FZR 600. Part number should be 4HM-2581T-11-00 if my research is right. If you get non yamaha rotors (like EBC or Galfer) then getting a set for a FZR600 or US Spec 94-95 YZF600R should do the trick.
Hope that helps
Hope that helps
D,dougs wrote:I have got to replace my front rotors (discs) are the fzr600r discs compatible with anything else? the newer yzf600 discs are bigger and mount differentlyi have looked at the wiki and the foxeye 94/95 is not shown can anyone help?
You will need to look at the Mico-fiche' for the foxeye series there should be a link to M-fiche' in the WIKI get the part number for the disk then compare that to the '90+ series of FZR's they should be the same BUT I am not sure.
Even if the discs are bigger once the mounting holes are the same you are cool you then just need to make a caliper mating plate to suit
To give you an idea take a look at:
http://www.saltmine.org.uk/kgb/gallery.html
You will see with all the RD's Blue streak etc the discs were never native to that model .
When you find the answer please contact me OR put the info in the WIKI for all the other guys & gals who come after you.
Thanks
thanks for the info i will go to the breakers and get some disks and check
edit
i have just checked part no.s and the fzr 600 89-93 are exactly the same 298mm dia so once i have confirmed it and got em bolted to my bike i will update the wiki
edit
FZR600R '94'
Bluespot calipers
Wavey front discs
Bluespot calipers
Wavey front discs
D,dougs wrote:thanks for the info i will go to the breakers and get some disks and check)
edit
that is what I like to see the helped helping the next guy along
