CVK 34 Keihin - Float level!
cs_05_hho
Post by cs_05_hho »
Hello Guys! Sorry for creating this topic, but couldn't find the proper one... so here it goes:
On my YZF 600R 4jh (FZR 600R - for Europe) - I run stock carburetors - Keihin CVK 34 - I am planing to give them a full clean-up - please tell me what is the proper float level for the stock setup? On the 3he I've heard it is 23-24mm... is it applicable for the 4jh as well? And regarding the fuel-air ratio screw how many turns should it be out? I've turned it 1.75 turns... wasn't quite satisfied with the idleing... turned it 2 turns out from zero and the idleing was getting a little better - did you guys have more turns out?
Thank you!
tclayton9
Level 2.5
Level 2.5
Re: CVK 34 Keihin - Float level!
Post by tclayton9 »
I believe the float levels are around 23-25. Stock the idle air mixture screws are 3 turns out. my2cents
cs_05_hho
Post by cs_05_hho »
thank you!!!!
