My FZR600R Foxeye Restoration
cad600
Re: My FZR600R Foxeye Restoration
Post by cad600 »
The Foxeye and Thundercat both use shock about 360mm long. The YZF750, Thunderace (YZF1000) and FZR1000 all use shocks that are about 340mm long.
I don't think it is a 750 shock though. Here is a picture of my stock 750 shock. It does not have the top spring compressor as in your picture.
dougs
Post by dougs »
Hells bells keep finding faulty parts on the rear suspension the bottom shock mount and the main swing arm bearings are all shot, not happy
this is the bottom bearing for the shocker
all the needle rollers have fallen out of the swingarm bearings
and the shaft is totally u/s as well
time to get fixing,,,, i have a plan
FZR600R '94'
Bluespot calipers
Wavey front discs
R6 front mastercylnder
Mild steel chain adjusters
Art can with removable baffle
Carbon fiber chain guard
Glass fiber rear seat-hump
Yamster
Donating Member
Donating Member
Post by Yamster »
The beauty with buying 20 yr old second hand bikes sometimes Doug.
Makes you wonder what some people think,a wrench i ain't,but somethings are not that hard.Makes you think some people dont deserve a bike.
I had a kawi that i had to take to an enginneers,just to get the swing arm bolt out once.I litrally destroyed the swing arm bolt with a lump hammer(4lb)and chisel braying it,and the thing still would'nt budge :swear .
Good work there though friend,at least when its done,you will know its right :thumbsup: .
dougs
Post by dougs »
ok clean up time been busy sorting out all the good bits from the bad bits ready for rebuilding, still have a choice to make on the swingarm though option1 is i get a new set of bearings and bush bar for £44 plus postage or i get a whole swing arm from the breakers for £25 all in. Any way photos of the clean up so far;
back wheel all cleaned up
sprocket, rear wheel spacers and adjusters all ready for assembly
swingarm end plates cleaned up ready for paint
rear caliper bar all painted up ready
wheel alignment plate painted
my new tricasting should come soon so should be able to start putting her back together soon
FZR600R '94'
Bluespot calipers
Wavey front discs
jallen
Post by jallen »
Out of interest where do you get Bearings and the bar for £44? I am hoping the swingarm/suspension bearings on mine are okay.
The bike came with a list of things that needed doing from a fairly well respected bike shop so I am hoping that they wouldn't have missed the swingarm. They picked up that one fork seal had a slight leak and that the rear wheel bearings needed replacing so I am hoping not.
Also, in an earlier post you mentioned cleaning the sight glass window are you able to do this without dropping the sump off?
John
1994 FZR600R
dougs
Post by dougs »
Ok the swing arm bush and bearings are from yambits on eBay and it is very easy to miss the swing arm bush and bearings you really can't tell till you strip it all down
As for cleaning the sight glass I simply emptied the oil and removed the sight glass with a seal removal tool (like a dentist tooth pick) best to put it back with some gasket sealant if you use the original just to be sure it won't leak
FZR600R '94'
Bluespot calipers
Wavey front discs
dougs
Post by dougs »
ok lots of new and repaired bits to put back together
painted swinger
box of cleaned up parts ready to go back on
and last but not least the new swingarm bush and bearings
Swinger before it was cleaned
FZR600R '94'
Bluespot calipers
Wavey front discs
jallen
Post by jallen »
The swingarm looks really good what was it done with.
John
1994 FZR600R
dougs
Post by dougs »
Hi John I cleaned it up and wet sanded it then flapwheeled all the welds that were not clean and then sprayed smooth hammerite silver as it's a fairly soft paint it should be pretty long lived, I used it a few years ago on my diversion swingarm with good results
FZR600R '94'
Bluespot calipers
Wavey front discs
dougs
Post by dougs »
all back together at last
unfortunately this job has raised loads of new jobs i now have to do but the bike is now fully working yipee
FZR600R '94'
Bluespot calipers
Wavey front discs
jallen
Post by jallen »
Looks really good but I would tempted to mount the rear shock reservoir above the subframe lower rail assuming it fits of course.
John
1994 FZR600R
dougs
Post by dougs »
Thanks I will have a look and see if it fits I have got to make a bracket for it as well don't like fixing things with ty-raps
FZR600R '94'
Bluespot calipers
Wavey front discs
jallen
Post by jallen »
dougs wrote:Thanks I will have a look and see if it fits I have got to make a bracket for it as well don't like fixing things with ty-raps
The tie wrap thing is a bit rubbish. On the YZF750 there is a bracket attached to the rail which a jubilee clip passes through.
The bracket on the PowersportsPro site is showing as being on backorder but it would be neat. I am rubbish at metalwork but making a bracket like that wouldn't be too difficult.
John
1994 FZR600R
dougs
Post by dougs »
thanks John i have moved it and it looks way better i am definitely going to make a bracket will post a pic when i have done it your diagram has given me some useful inspiration!
ok so i have now made a bracket;
fabricated it out of some scrap aluminum bits i had and welded them together with tecno weld fantastic stuff and really easy to use bit like lead soldering
the finished article
FZR600R '94'
Bluespot calipers
Wavey front discs
apsolus
Level 2.5
Level 2.5
Post by apsolus »
wow thats better than stock. super cool how you hid it
