New on the forum, figured I'd put up some pics of my trusty warrior.
Started the build back in 2002 and it has been through a couple of reincarnations since, but the base has been pretty much the same.
Based on a 1989 FZR1000, I happened to stumble over a NOS 1993 engine that immediately found its way in between the frame spars.
Looked like this in 2004, Kawi green just because... :
The evolution continued and in 2006 I did a slight overhaul.
Powdercoated frame:
Hardware zinkplated yellow:
White paint:
Came out like this:
Only engine mod is a removed airbox snorkel and jetting to suit (ended up with 150 mains), put out just under 138 rwhp on the dyno.
Specs:
1989 FZR1000
1993 NOS engine
Homemade subframe
Ducati 916 tailunit with homemade seat
Homemade dogbones (10mm shorter)
Stainless steel undertail
Modified gaugecluster (speedo removed)
Homemade handlebar risers
Twin Bates headlights
R1 goldspot front calipers
Ducati 996 front discs
Shortened Yoshimura can
Fly moto-x bars
Cheers
/Daniel
