dirtbike handlebar mount???
For the bad boyz, here a little arena for you to get fightin'!
jmarcy85
Post by jmarcy85 »
Im wanting to mount dirtbike bars on my 89fzr600 and was tring to figure out how the best way to do this is. I can make the mounts if i need to but if there is a dirtbike triple tree that will bolt on i rather go that way. I also wondered if the stock trees would loose there integrity if i started drilling on them.
Bratman3401
Re: dirtbike handlebar mount???
Post by Bratman3401 »
you should upgrade the front end and almost any new front end will have a bolt on solution
Post by thatkid »
Drilling the stock trees shouldn't do anything you'd need to worry about strength wise. There is a top that fits that comes with risers built in but it's hard to find. The seca II's had risers OEM. They are pretty hard to find in the states though.
Post by thatkid »
Bratman3401 wrote:you should upgrade the front end and almost any new front end will have a bolt on solution
Also posts like this aren't helpful. It doesn't answer any of the questions he asked.
Bratman3401
Thats all i said because i didnt know about the other stuff i thought i had seen some for the fzr but i cant remember where so it would of been pointless to say anything about that i just wanted to give him ideas so he isnt sitting wondering when he will get a reply
jmarcy85
Post by jmarcy85 »
i would like to just buy the mounts but there isnt any mount holes on the triple tree.......i guess i will just have to find newer trees for super cheap?
Post by thatkid »
jmarcy85 wrote:i would like to just buy the mounts but there isnt any mount holes on the triple tree.......i guess i will just have to find newer trees for super cheap?
Do you have mounts in mind?
JRK5892
Level 1.5
Level 1.5
Post by JRK5892 »
man what i would sugest is... drilling them out, get a set of dyna (harley) poly riser busings... then pop those suckers in there, any 7/8 bar and riser set up will work just fine
before you drill make sure you make perfect center on the bike and figure out just where you want them... then drill away
http://www.thepowderpro.com
The Powder Pro
ragedigital
4000+ Posts
4000+ Posts
Post by ragedigital »
You can always check out these from Spiegler: http://www.spieglerusa.com/RiseUpClamps/
veilside803
Post by veilside803 »
ragedigital wrote:You can always check out these from Spiegler: http://www.spieglerusa.com/RiseUpClamps/
Finally a site thats straight up what im looking for....
Edited- making own thread.
TY for link btw
Return to “Streetfighter'd / Naked / Chopped”
