Is that an R6 header mating with a FZR motor?
This area is owned and operated by ThatKid (Nate)
zero9243
Level 8.5
Level 8.5
Re: Is that an R6 header mating with a FZR motor?
Post by zero9243 »
YAM93 wrote:I've already scoped out a particular local interstate.
I find myself violating the speed limit by a lot lately, about 75% of the time I ride. It's addicting.
I really need to get back to the MX track before I kill myself, haha.
:duh:
haha nice man. Yah that pipe looks incredibly sexy. I like the work you're doing on the fairings. looks like you're taking your time and making sure it looks good. I like that about a man :whistle :whistle
lol but seriously lookin good. GET A VID UP! :banana:
Upgrades:
YAM93
Post by YAM93 »
Sounds like the video will be about another 3 weeks, as, the guy I'm borrowing it from's in-laws are coming into town and they just had a baby boy. Anyway, I have one other thing to say today:
Latest update: As the directions called for I finally took some Windex to the pipe and cleaned it up real good. Also the high-temp silicone is fully cured now so they said to let things get up to "operating temp" and check for exhaust leaks. I didn't see, hear or feel any, but I'll keep my eyes / ears open for the next few weeks as I ride more.
"SEAT OF THE PANTS DYNO" -- I took it for a brief test ride in the parking area. My guess is I got another 5 Horsepower from this set-up vs. the V&H SS system. I can only tell by the fact that I usually crank on it in first gear after already moving around 4-5k RPM and it will lift about 2 inches off the ground if I give it a little pull. Now I do the same thing but come up almost 24 inches.
:-D :-D :-D :-D :-D :-D :-D :-D :-D :-D :-D :-D :-D :-D :-D :-D :-D
Of course having the 14-47 / 520 set-up helps a lot also, but that was already installed last year. So I'd say I'm VERY HAPPY so far. Tomorrow I'm riding it to work so hopefully eveything will stay good.
It sounds pretty good and is still quite loud, but definitely quieter as I can hear a lot more of the transmission and engine noise.
It's also amazing how much faster the Titanium disperses the heat than the steel header, although this makes no difference one way or the other.
Also, I only rode it for 15 minutes but the rear turn signal does not seem to be affected, didn't melt or even get warm.
ragedigital
4000+ Posts
4000+ Posts
Post by ragedigital »
YAM93 wrote: My guess is I got another 5 Horsepower from this set-up vs. the V&H SS system.
You're ready for the Honda Civic forums where they get 12 HP just from changing rims.
demon_knight69
Level 4.5
Level 4.5
Post by demon_knight69 »
LOL2 and an extra 5hp per sticker.
1996 FZR 600
K&N Pods
Barnett Clutch
Factory Pro shift kit
Post by thatkid »
Hey less rotating mass can equal more hp.... :whistle
Yam, I'm just glad you are happy with the headers. I like satisfied customers! Plus now you can sell off that V&H once you clean it up a bit. Probably get more than what you paid for the header.
YAM93
Post by YAM93 »
No, the clamp came with the FMF pipe.
Guys, come on now, you know I hate Civics. And, for those who don't believe me, come on down and we can switch the systems back and forth. I swear on both my grandparent's graves it's at LEAST another 5 horsepower, seriously. Don't be jealous now.
I promise I won't use the extra horsepower for evil.
bonkonhead
I will say that it has definitely enhanced most of that horsepower in the midrange and the high-end though. From what I can tell so far. Haven't taken it over 100 mph yet though.
:banana:
Keep in mind that it's NOT JUST the pipe, but also this R6 header being DEFINITELY better than the V&H 4 into 1 type.
Really can't be any other explanation, I didn't lose weight or use any different gasoline.
RoadDogma
Level 1.5
Level 1.5
Post by RoadDogma »
[/quote]
Not sure what you mean by the runner diameters... The actual tube? Stock FZR is 32mm for the tube and the R6 is 35mm. The outlet for the R6 is 44.5mm outside diam and 41.23mm inside or 1.75" and 1.62" respectively.[/quote]
Is that R6 = 35mm Inner diameter or outer diameter?
Post by thatkid »
Is that R6 = 35mm Inner diameter or outer diameter?[/quote]
That is the outside diameter of the pipe.
I just made my first post from my new iPod touch. That's pretty damn cool I think.
AraiPnai
Post by AraiPnai »
YAM93 wrote: Guys, come on now, you know I hate Civics. And, for those who don't believe me, come on down and we can switch the systems back and forth. I swear on both my grandparent's graves it's at LEAST another 5 horsepower, seriously. Don't be jealous now.
dam.. i have a civic.. :( but i feel you! i hate em too, that's why i got an fzr.. hahaha.. i'm interested in this mod though.. o.O
SSDD
Don't complain to me unless you can offer a solution too.
Whenever things go to sh*ts and don't go the way you'd like, I blame it on the fact that "the world is ending."
Sept '03 - June '04 : '89 FZR 400
April '08 - Present : '97 FZR 600
http://maked-up.webs.com/ http://www.thenutshack.net http://motorcyclemadness650.com/
YAM93
Post by YAM93 »
Ok, tonight I got the fairing closure piece from ThatKid. Very nice, especially considering i gave him a pencil sketch on a scrap of cardboard.
I'll get some Lockhart Philips metal fairing screws/rubber nuts tomorrow and it will be attached nice and solid. Right now I have the original fairing grommet and a plastic Honda windscreen screw in there and another plastic screw just temporary. Even this withstood some pretty good wheelies tonight.
Now, if my power supply for my computer will come in, maybe there's a chance of posting a video within the next week, even though I still doubt my DVD RW will read the guy's disc. I think he burned it in the wrong format. Anyway, I'm going to order a firewire cable tonight so hopefully can re-borrow his camera next week and use my Nero video plug-in which should work once my computer is working. Yeesh, such a set of dominoes.
Now to talk about (due to new dogbones) the possibility of a custom aluminum bolt-on kickstand extender. Because she leans a bit too far now.
Just in case you were wondering, I have to give 1000 kudos to ThatKid here, if I didn't know any better, I'd think this little plastic piece came directly from the factory at Yamaha. VERY NICE.
:udaman
ragedigital
4000+ Posts
4000+ Posts
For $50, I'll drop off my R6 header at Nate's house, then he can do the work and send it out for what ever he charges. I've already ground down the old weld and it's ready to be welded up.
YAM93
Post by YAM93 »
that sounds like a damn good deal for 5 hours driving each way.
:banana:
ragedigital
4000+ Posts
4000+ Posts
Well, I need to get to Chicago sometime in the coming weeks and I'll just throw it out my window as I pass by Nate's house.
Post by thatkid »
ragedigital wrote:Well, I need to get to Chicago sometime in the coming weeks and I'll just throw it out my window as I pass by Nate's house.
Let me know and I'll be there with a mattress! We don't want to dent it now do we? :rofl:
YAM93
Post by YAM93 »
http://www.youtube.com/watch?v=4iPjgTz1TtI
Finally after a month of waiting, here's the video. Sounds even better in person... YouTube kind of kills the quality of the video.
I try to shamelessly plug FZROnline.com as much as possible.
:banana:
Return to “Green Machine Customs [Custom Fabrication / Machining / Powdercoating]”
