I painted the fairings earlier this year and finished wet sanding this weekend (1500 and 2000 grit). There was a good amount of orange peel. The parts were hand buffed and polished. However, the finish is still hazy. I'm using cloth and foam applicator pads and Mequir's rubbing and polishing compounds. I tried using less product, more/less force, and working until the product was clear then removed with a cloth towel before it dried.
Hand buffing is exhausting. I am looking to buy a DA polisher or traditional buffer.
Any suggestions?
Any Paint Gurus on the Forum?
Re: Any Paint Gurus on the Forum?
Contacted the paint shop and was told I have to use a machine. The clear coat is too hard to do by hand.
Some clear coats work much better than others. What brand did you end up using?
I used a 2 part spray with really good results ::
http://www.eastwood.com/spray-max-2k-hi ... nt_reviews
Interesting product. Two stage paint in a rattle can. How did it turn out?
It's a mid-grade base/clear paint called Utech. It was highly recommended for my application, skill level (beginner), and budget.
Here are some pictures after the rubbing compound was applied:
http://klutchimages.mypearson.info/imag ... 110244.jpg
http://klutchimages.mypearson.info/imag ... 110250.jpg
http://klutchimages.mypearson.info/imag ... 110251.jpg
Sorry for the big files. I was too lazy to knock 'em down.
The buffer made a big difference. If you look closely, you will see flaws. I wasn't looking for show room quality. The next step is polish.
The bike is actually practice for a '79 z28 that I am restoring. This is only the second vehicle I've sprayed and the first that I have tried to finish.
