Hi there
Im in the process of putting the triple trees back on my FZR250 but I didnt take a photo of how the bearings and crown nut go together and can not seem to find any diagrams showing the assembly. I have three part I am struggling with. The two bearing plates ( which on goes on top or the bottom) a hard plastic/rubber ring and the crown nut. Could anyone be so kind as to take the top triple tree off their FZR250 and show me what it looks like assembled or if anyone has a diagram or assembly guide it would be much appreciated. Thanks
Steering stem assembly Help please!
Re: Steering stem assembly Help please!
Cheers! good help
- Camala_Pillion
X,
the diagram is good but does not show that the frame "neck tube" goes between items 1 & 3 and also that some Yamaha models have a rubber ring at the vey bottom of the lower triple tree UNDER the bearing race. Not sure if the 250 is like that since i have never seen or worked on one
