88 fzr 250 2kr float heights
Posted: Wed Aug 10, 2011 3:15 pm
by wombat75
hi there i just purchased a 88 fzr 250 2kr that has been sitting 4 a few years, problem is i can't find carb float heights??, workshop manual only talks about float levels, Have removed & cleaned carbs, replaced plugs & oil, refitted carbs 2 find 1 & 2 carbs flooding, removed carbs again & measured float heights found 2 be 11mm raised to 11:7mm, now won't idle & won't go to max rpm in 3rd gear
Re: 88 fzr 250 2kr float heights
Posted: Thu Aug 11, 2011 10:50 am
by ragedigital
*Moved thread to the appropriate sub-forum. May help you get an answer.
Posted: Thu Aug 11, 2011 11:42 am
by zero9243
hm did you try bench syncing the carbs before putting them back on? How far apart did you take the carbs when cleaning them? Did you make sure the pilot jets were nice and clean
Posted: Thu Aug 11, 2011 9:51 pm
by wombat75
ragedigital wrote:*Moved thread to the appropriate sub-forum. May help you get an answer.
sorry having trouble finding thread could u pls post link here thanx
Posted: Thu Aug 11, 2011 10:26 pm
by wombat75
zero9243 wrote:hm did you try bench syncing the carbs before putting them back on? How far apart did you take the carbs when cleaning them? Did you make sure the pilot jets were nice and clean
.The bike was idling fine at 11mm float height, just would start leaking fuel out carb overflow after about 10 mins idling, but i didn't roadtest. When i cleaned the carbs, i didnt seperate or touch any adjustments & made sure all jets were clean plus didn't mix them up. I have been measuring heights with verniers to be precise. I'm close but need specs. What do u mean by bench synch?.Plus a trick i learnt is soak carbs in lemon juice 4 about a hour cleaned mine up a treat & they were dirty as never been touched.
