Alternator Problem (i think)
FZR250 Forum
BoD
Post by BoD »
Hey
I think my alternator is screwed
So far what i have done is
Disconnected the positive terminal of the bike, and tested for leaks
(no leaks)
Measured the voltage across the battery, and it didn't raise as i revved it
Tested the white leads going in to the regulator/rectifier
i read 30-60vac across each pair when revving
How ever the Alternator is coils on the fly wheel, and is a non moving part, therefor rarely breaks
Is there any other test i can do to determine the problem?
Thanks
Richard
FZR250 2KR 1988
Re: Alternator Problem (i think)
if we had some clue from you about year/ and market model (ie your location in your personal profile ) it would probably help.
the Wiki has a section on trouble shooting the charging system which would be of use may be..............
BoD
Post by BoD »
Oh sorry, wasn't thinking
FZR250 2kr 1988
FZR250 2KR 1988
As discussed on FZR250.com, 30-60vac on all 3 legs = a working alternator. If your battery isn't charging, then it's either the battery, the VRR, or the wiring in between. There may be a 'leak', a short that drains the battery without passing enough current to actually blow a fuse.
BoD wrote:Oh sorry, wasn't thinking
FZR250 2kr 1988
B,
Well that is a start but where ?
Bikes are not built in Japan to one spec the spec varies as to what market it gets sent to USA has diff emision specs to Europe . Lights are wired permanently on in some countries and manual in others.
As for the engine electrics they are the same basic layout ie alternator/ Volt regulator/ battery charging system.so:- take a look in our very extensive WIKI for electrical trouble shooting.
In this case they WERE built to one spec, as the FZR250s were JDM-only. All examples found elsewhere are grey imports.
Don,
cool , just wonder how a Uk owner would get on with the lights pointing the "wrong" way for the DMV
(can't delete my own bloody double posts?!) :headscratch:
IIRC, the Japanese share the trait of driving on the wrong side of the road with you chirpers... :mrgreen:
