Hi Guys,
have just got my bike on the rd but am having a problem with selecting neutral, when the bike is off i can select neutral but if the bike is running no matter how long i sit there trying i cant find neutral and just skips straight to second. anyone ever have this problem??? or know why its doing this. when riding it goes up and down gears perfectly just not into neutral.
also what level should the oil be in the window?? i have seen posts about 2 marks but mine doesn't have any. at the moment the oil is right over the window and ill be doing a change this weekend.
thanks for any help
cant select neutral
Re: cant select neutral
This is actually a common problem in many (if not most) bikes, inherent in the transmission design. Try adjusting your clutch and - as you say - get some fresh oil in there.
- willandrip
- Level 7.0
When marks are visible they are ;
Half way up sight glass = lowest recommended level.
3/4 way up sight glass = full level.
A completely full sight glass indicates overfilling provided the bike is standing upright and level.
+1 on the oil level and as far as shifting, if it has an aftermarket "shift star" installed it makes finding neutral much more difficult.
Yes I realize this is an old thread and that the OP only has one post.
