hi i wanted to know there i can get a carb kit for my bike and is it worth the money
the bike has a flat spot between 4 and 8 000 revs
and took it in for check and they said it was the nozzles and they cant get parts for the carbs and yamaha said they cant get it
so i have to get new carbs or get kit and also what motor will fit in the frame of the 3ln3
where can a get a fzr 250 3ln3 carb kit
1991 yamaha fzr 250 r 3ln3
Re: where can a get a fzr 250 3ln3 carb kit
There's a fellow selling carb rebuild kits here, on the Archives, and on FZR250.com. This is the rubber bits, and they can have sufficient effect on these carbs to mask or imitate jetting problems. That said, I'm not aware that these bikes have major problems with the nozzles - certainly not the way the 1ks etc eat through theirs!
The part number is 3LN-14141-28; it is available on-line here and here.
thanks i will check the carbs again and thanks for the link will keep you posted
- GreyImport
Do a carb clean and balance
Take a look here
http://2fiftycc.com/index.php?threads/l ... zeal.1043/
Most mechanics dont want to touch carbys on old bikes so you will get excuses like "no parts available"
Take a look here
1990 FZR250R 3LN1
![Image](http://i108.photobucket.com/albums/n30/BrianFromOz/RED3_zpsdaaeacec.jpg)
![Image](http://i108.photobucket.com/albums/n30/BrianFromOz/250png3_zps86b1eaaf.png)
LiteTek Carburettor Seal Kits
