Stator
FZR250 Forum
madchild
Stator
Post by madchild »
What,s the craic lads, i went to take off the stator there this evenin and it wouldn,t come out of the casing.
It seems like it has been a long time since it was removed i have sprayed some wd 40 in there i,ll let it sit for a few hours but if it doesn,t free up what could i do i don,t want to smack the casing in case i crack or break it any suggestions?
I want it out so i can clean the casing for respraying.
I know a good belt of a rubber mallet might shock it free but it might also bust it in bits ya know :headscratch:
SouthendChris
Re: Stator
Post by SouthendChris »
The screws that hold it in the casing have a load of threadlock on them to stop the stator coming loose and clouting the flywheel. You could try warming up the stator housing the other side to the mounting screws to free up the threadlock a bit. Dont get heat/naked flame near the stator though!
Chris
3x RG80 Gamma :)
GreyImport
Re: Stator
Post by GreyImport »
Leave the hammers on the bench :duh: :rofl:
Use a hexkey socket like these.......best thing I ever bought.......
If u need more grunt then use something like this....its all about leverage, not brute force ....which tends to break things :grinnod:
Just use slow and steadily increasing pressure
Or if u only have a normal hex key slide on a piece of pipe slightly larger and longer to give u some grip and leverage.
The pipe extension method works well on the socket wrench also
My weapons for threadlocked and rusted nuts and bolts....... :thumbsup:
1990 FZR250R 3LN1
http://2fiftycc.com/index.php
LiteTek Carburettor Seal Kits
Re: Stator
Thread lock breaks down under heat. If red locktite was used (it should have been blue), without heat you'll round the heads out of the Allen screws before you get them loose. Carefully get in there with a heat gun or torch.
madchild
Re: Stator
Post by madchild »
Sorry i should have mentioned i have the bolts out it,s the actual stator that seems to be stuck to the casing.
Although looking at it this mornin it seems like it might free up there is a little play in it now :tks:
Yep got it free from the casing but the two screws just above the stator itself are stuck. I thought i put some wd on it last night can,t remember though i was :drink:
Anyhow i,ll battle on.
