so i got a problem with my bike.. most probably a carb issue..
i got a fzr250r 3ln1 1989 with the bdst28 carb
checked out this forum for weeks finding out what all you guys have done to your bikes and i decided to have a go myself.
took the carbs out to give it a clean and did some adjustments here and there.
the bike was running well (really well before i did the adjustment) but now its all gone to shit.........
ok current settings
idle air screw set to 3turn out from the bottom
float heights (as in in the float chamber) is 13mm from the gasket
havn't changed the jets or anything they are all factory.
.. thats basically all i changed.. i dont know what it was originally as i didnt think at the time to measure it before i changed it.
symptoms are
1. the bike doesnt start so nice.. i have to put the choke on full, press the starter button and give it a little throttle and then it starts (cold starts) when the bikes warm no choke but still needs throttle to start. this could be because in order to take the carbs out u have to disconnect the throttle cable so may be i changed that in a bad way when putting it back.
2.the bike has gotten sooo sluggish under 12k rpm... i used to have power from 6k upwards
3. the idle seems like not enough fuel is going in (actually while i ride the whole time i feel there is not enough fuel going into the engine) feels like its gonna die at anytime
ok thats it i think.. please let me know if anyone here has any advice..
cheers - Aaron
