Hi
Does anyone know what size screw the engine temperature sensor is which screws in on the radiator cap? Specifically the 2kr? And does anyone know the normal temperature range for normal running and what temperature is considered overheating for the engine?
THANKS!
Engine Temperature Sensor ??
LoneFizzer
Re: Engine Temperature Sensor ??
Do you mean the thread size or the actual wrench size? Thermostats usually open around (depending on climate) 190 °F and 204 °F, anything above those figures may be considered as overheating.xelif wrote:Hi
THANKS!
