My fzr wont run after the mechanic touched her
ssimonn
Re: My fzr wont run after the mechanic touched her
I'm just going to tap the hole and shove another bolt in .
well thats the plan anyway.
FZR250R 3ln3 1991
NSR250R mc18 1989
NSR250R mc18 1989
You will have to be careful & remember the new torque value for that one bolt so easy does itssimonn wrote:I'm just going to tap the hole and shove another bolt in .
well thats my the plan anyway.
ssimonn
new torque value ?
I was thinking just do it the same as the other bolts
FZR250R 3ln3 1991
NSR250R mc18 1989
NSR250R mc18 1989
SSssimonn wrote:new torque value ?
Torque value is usually dependent on diameter and I got the impression you were going to tap the hole with a slightly larger thread and use a bigger diam bolt.
did I read that correctly ?
The way round using a bigger stud is using an aero -style nut that will not back off and use the same torque as the rest that way it will not shake / back off and cause a leak because the gasket is not "pressed" equally.
ssimonn
I was going for 7mm - 1.00 (11mm Hex) 30mm , as this is the closest I could find.
But I'll google this aero-style you mention cause I'm not sure what your are talking about there YG
FZR250R 3ln3 1991
NSR250R mc18 1989
NSR250R mc18 1989
ssimonn
ah , so i fix a stud in the hole that was threaded , then just screw a nut down . Which would be nice but it might get in the way when doing valve clearances.
FZR250R 3ln3 1991
NSR250R mc18 1989
NSR250R mc18 1989
ssimonn wrote:ah , so i fix a stud in the hole that was threaded , then just screw a nut down . Which would be nice but it might get in the way when doing valve clearances.
SS,
As they say a picture etc.
yup a bolt then is the way to go .
Aero-nut is a deformed nut so the threads grip tighter and do not back off pre-runner of nyloc nuts
see:-
http://cgi.ebay.co.uk/TURBO-EXHAUST-STA ... 0598659261
ssimonn
thanks YG , I had not seen those before.
FZR250R 3ln3 1991
NSR250R mc18 1989
NSR250R mc18 1989
SS,ssimonn wrote:thanks YG , I had not seen those before.
When you have hung around cars/bikes etc for 50 years you do see a thing or two ....... as you get older remembering what you saw is the trick LoL
ssimonn
Plans have all changed and the bike is staying , so it's getting stripped down and cleaned up all over. If I am super lucky it wont cost to much
It'll look something like this when done , I might even use the decals just to confuse people
FZR250R 3ln3 1991
NSR250R mc18 1989
NSR250R mc18 1989
SSssimonn wrote:Plans have all changed and the bike is staying , so it's getting stripped down and cleaned up all over. If I am super lucky it wont cost to much![]()
It'll look something like this when done , I might even use the decals just to confuse people![]()
You will not be the first one to hide a bike in plain sight for sure BUT do not expect any thanks from the purists
see:-
http://www.saltmine.org.uk/kgb/greenbean.html
That one almost caused a fist fight at a bike show when some A W objected to it being shown in a yamaha RD400 show tent, he objected to the paint work so the owner objected to his yamaha which was in white with multi coloured polka dots (I kid you not ).
petterwilliam
I am looking for good bike mechanic for my bike those know the proper knowledge about bikes parts and proper repairing of it. Actually I want my personal mechanic those repair my bike properly.
bike mechanic
bike mechanic
hi,petterwilliam wrote:I am looking for good bike mechanic for my bike those know the proper knowledge about bikes parts and proper repairing of it. Actually I want my personal mechanic those repair my bike properly.
bike mechanic
I know a good mechanic in Queensland Australia and a guy in Trinidad west indies, but since you do not tell us where you are that is as much as you are likely to be told .
PUT your LOCATION in your PERSONAL PROFILE.
