Page 1 of 2
Right-angle battery post thingies
Posted: Mon Jun 09, 2008 10:47 am
by tommyj27
When I replaced my battery a while back I forgot to remove the right angle terminal doodads that allow the cables to attach horizontally rather than vertically. I have been getting by with the cables attached horizontally but it's really obnoxious whenever I want to unhook the battery. Are these some sort of standard part that I can get at the stealership or an auto parts store, or are they FZR specific?
Re: Right-angle battery post thingies
Posted: Tue Jun 10, 2008 8:58 am
by tommyj27
*bump* - Beuller? Beuller? Beuller?
Posted: Tue Jun 10, 2008 9:42 am
by Fizzinatorr
On my battery you can just flip the metal piece that goes on the battery itself
I want to help but I'm not 100% on what you're referring to on this
If you can take a picture i can help you better
Posted: Tue Jun 10, 2008 9:47 am
by haunter
uh yeah pics plz
Posted: Tue Jun 10, 2008 10:20 am
by tommyj27
I would post pics, but i'm missing the part. I'll try and sketch something.
Posted: Tue Jun 10, 2008 11:03 am
by tommyj27
Here is my awesome sketch of the part I'm wishing I still had. I don't recall if it was bolted or screwed to the battery post, but I do know that the power cable screwed into the right angle thingy. Does this make any sense?
Posted: Tue Jun 10, 2008 11:06 am
by haunter
aaaah gotcha
I dont have those either
Posted: Tue Jun 10, 2008 12:26 pm
by tommyj27
So your battery is connected like so?
That sucks, unhooking the battery was 10 times (exactly
) easier with those. I imagine they could probably be fabricated w/o too much trouble.
Posted: Tue Jun 10, 2008 12:38 pm
by haunter
nope........
screwed in from the top down
i dont have a battery box on the 600 at the moment...need to fabricate something that will pass tech at a track sometime this summer
Posted: Tue Jun 10, 2008 12:50 pm
haunter wrote:nope........
Guys,
a heavy duty bit of alloy will do the trick (my trini bike has them so no photo) but they are a good 1/10 or 1/8 thick right angled bits the heavier the better for current flow, brass may be better if you can get it Nerd
Posted: Tue Jun 10, 2008 1:37 pm
by haunter
I ain't that worried about it yet, but thanks, I'll keep my eye out and nap something if I see it
Posted: Thu Jun 12, 2008 1:21 pm
by tommyj27
That's what i'm looking for; I guess my original diagram wasn't terribly accurate, or I just didn't remember it quite right. Are your battery posts threaded so you can screw straight down, or is the "screw down" a removable doodad that bolts onto the battery post? I thought they were removable pieces on my old battery because I thought I had tightened them down at one point.
Posted: Thu Jun 12, 2008 2:52 pm
by haunter
i have the standard 'box' for a post......that you insert a recatngular theaded plate into and the screw goes through a hole in the top into the plate...
Posted: Thu Jun 12, 2008 3:29 pm
haunter wrote:i have the standard 'box' for a post......that you insert a recatngular theaded plate into and the screw goes through a hole in the top into the plate...
Haunter,
can you get a picture to clarify this for the readers ?
Thnx
Geo.
Posted: Thu Jun 12, 2008 4:00 pm
by tommyj27
Yeah, if it's not too much trouble I'd appreciate it. Sounds like what I'm looking for. Or if you can find a pic online...like at bike bandit or someplace i can buy a set *wink wink*
