cad600 wrote:Even with all of the mods I'm doing, I don't have the cajouna's to drill into my engine case like that. Good work man.
do u have the write up & the dimensions95FZR600 wrote:Posting some pics and such for ya'll that could start the WIKI spot for it and then tomorrow I will work on a write up. I have web site info for the speed healers and Msilves that makes the tach converter kit.
I have put 3,000 miles on bike since drilling the hole. Same engine!nynoah wrote:dude, did you drill your engine cases with all the tranny parts in place? Because if you did, kiss your engine goodbye. There is going to be metal shavings all over inside there.
I have 13000km on it since drilling, and no problems at all. The engine runs as smooth as the day I got it, and haven't noticed anything out of the ordinary. If you do it carefully, shouldn't be an issue. Also, the casing is a much softer aluminum while the tranny is hardened steel. There is not a drop of oil at the sensor, and because of where it sits, it is pretty much out of the elements. There is no way that is coming out of the case.nynoah wrote:dude, did you drill your engine cases with all the tranny parts in place? Because if you did, kiss your engine goodbye. There is going to be metal shavings all over inside there.
