integrated tail prob....
Posted: Tue Jul 14, 2009 6:23 pm
by tampaFZR600
I did the write up, and all my connections are correct....I can't get both to work. it works for ONE bulb, but LEFT AND RIGHT do the same bulb.....any ideas??
Re: integrated tail prob....
Posted: Wed Jul 15, 2009 8:56 am
by tampaFZR600
thanks for the help fellas.....
Posted: Wed Jul 15, 2009 10:32 am
by reelrazor
Hey...you gave it a whole 16 hours!
I tried the tailight integration thing about three years ago. I can't recall what exactly was going wrong though. I know it wasn't right. The conclusion I came to at that time was that the integrator was messing with the flasher relay.
Maybe a different model/brand of trailer light control would have worked.
I dunno. I just put some minis right alongside my license plate and called it good.
Posted: Wed Jul 15, 2009 10:51 am
Click here and scroll down. "Poor Man's Tail Integrator"... Best way to integrate the stock tail I've seen to date
Posted: Wed Jul 15, 2009 2:50 pm
by tampaFZR600
Yes, i get it, i have been emailing Nealas fora day or so now....
I have the wiring right and now its blowing a fuse when i turn on the left blinker, the right one works....
Posted: Sun Jul 11, 2010 10:25 pm
by gillette
Hi everybody... I have a similar problem in that when I put the signal on for either left or right they both blink and it looks like I have my four ways on. I decided to do what reelrazor did and bought a set off license plate turn signals and was going to call it a day but it does the same thing! Now I dont know what to do because when i hook the stock ones back up to double check the connection is correct, they work. Any help would be greatly appreciated. Thank you
Posted: Mon Jul 12, 2010 5:57 am
gillette wrote:Hi everybody... I have a similar problem in that when I put the signal on for either left or right they both blink and it looks like I have my four ways on. I decided to do what reelrazor did and bought a set off license plate turn signals and was going to call it a day but it does the same thing! Now I dont know what to do because when i hook the stock ones back up to double check the connection is correct, they work. Any help would be greatly appreciated. Thank you
The only thing common to left & right is the ground if you hook that to the relay ..................
If you make sure the positive wires are not some how shorting together then they will work as planned .
Posted: Tue Jul 27, 2010 12:19 pm
by gillette
yamaha_george wrote:gillette wrote:Hi everybody... I have a similar problem in that when I put the signal on for either left or right they both blink and it looks like I have my four ways on. I decided to do what reelrazor did and bought a set off license plate turn signals and was going to call it a day but it does the same thing! Now I dont know what to do because when i hook the stock ones back up to double check the connection is correct, they work. Any help would be greatly appreciated. Thank you
How would I ensure that they are not shorting together? Is there a diagram somewhere? Someone mentioned that thereis a LED relay that can replace the stock relay that would fix the problem? Any siggestions?
Thank you very much for your help.
Posted: Tue Jul 27, 2010 2:07 pm
gillette wrote:yamaha_george wrote:gillette wrote:Hi everybody... I have a similar problem in that when I put the signal on for either left or right they both blink and it looks like I have my four ways on. I decided to do what reelrazor did and bought a set off license plate turn signals and was going to call it a day but it does the same thing! Now I dont know what to do because when i hook the stock ones back up to double check the connection is correct, they work. Any help would be greatly appreciated. Thank you
G,
there have been mixed results with so called LED only relays. This subject has recently been the subject of much discussion take a look thro' the older postings over the last 2-3 weeks maybe a month. for indicators not working.
I had mine working on my RD with LED 's all round but mine is NOT a relay but a timer circuit that does the switching. I got creative and opened the little black box, unfortunately everything has been covered in black glue so no components are readable how ever I was assured by an electronics guru such circuits can be found on the internet just they come in a slightly bigger "black box"
Found the design sheet I was given with the Electronic switcher see my new thread in this forum
