FZR600 VR Wiring
Posted: Sat May 02, 2009 12:26 am
Hey all,
Putting a FZR600 wiring harness on the 660 (in the 400 frame). I've got one of the newer wiring harnesses that plugs into my YZF600 voltage regulator - but, the FZR harness has an additional wire next to the VR plugin, with a black wire terminating in a small loop (just like you'd plug in the battery negative), so I'm assuming it's a ground. Question then : where is this plugged on the newer FZRs? Do I have to drill my subframe, or can I just stick it with one of the bolts holding the VR down?
Cheers!
JS
Cheers!
JS
