Brought it to my mechanic who also races and is an instructor, who safetied it for me and mentined how nice my bike rode etc etc. I pick up the bike from him ride it home but something just doest feel right ie throttle response, when taking off from a dead stop it bucks and jerks and needs ALOT of throttle to get going. This happened a few times last week and then finally it just died pulling up into my driveway. I tried restarting it but just clicking etc. I thought it was the battery because the battery I knew was 3 years old so I just replaced it.
Took the bike out with a brand new Yuasa battery and same thing! didnt stall at first but is choppy starting out in first, and even slowing down for a 20 mph corner in second you cannot accelerate smoothing out of second, just bucks and jumps back and forth for a few seconds before it catches.
I called my mechanic and was on my way to his house this evening and it just completely died half way there. I called him up and told him it wont even turn over it just clicks when you turn the ignition. Even the headlight and green neutral light were really dim! He gets there 15 mins later and fires it right up. WEIRD. He connected his volt meter to the battery and it was showing (if i remember correctly) just over 12 when reved up a little in neutral. Not bad he said but could be higher. He took it for a ride up and down the street and said it did not feel right. Power wasn't there and have to give alot of throttle to get going out of first. Gets back a few mins later and it stalls again! This time cannot get it started period. he rules out the carb as the bike was running mint for a month leading up to this the last 10 times I took it out and when he rode it to safety it. he thinks its an igniton, electrical problems but isn't so famliar with older bikes like the FZR's.
He gave me a boost which did work to get the bike started and i figured i'm good since my house was like 4 miles away. Well on the way home it stalled 3 times! everytime you stop for a light, you then try and open the throttle the tiniest bit and boom, stalls again and will not start. he was behind me everytime and also said the brake lights would dim and flicker right before it stalled everytime. Each time he boosted me to get going again the bike got worse and worse to the point where in second or third gear I'm giving it almost full throttle but its now wanting to go and infact even slowing down.
back at my house he checked connections, wiring, the stator the heatsink thing under the seat (forget what its called) to see if it was really hot and again nothing. EVERYTHING seemed normal. He was honestly baffled at this and told me to find a forum and see what info I could find out and if this is a common problem with these bikes.
Can anyone shed some light on this?
