crazy turn sugnals
Posted: Thu Jun 20, 2013 8:17 am
First off, I don't know how these worked before I got a hold of it, since all of the lighting was missing.
anyway, on my 97 fzr600, I installed an integrated LED tail light and front and rear led marker/turn signal lamps.
First of the weird:
The turn signal lights are 3-wire lights, so they are designed to run as marker lights on one wire and turn signals on the other, with a common ground. They work fine when tested on a battery , but when hooked up to the bike the lights won't work at all,not even the tail light. I have found out if I wire them differently to the bike, I can get them to work but the marker lamp will be full bright and will flash full bright with the turn signal on. No matter what I do, I cannot get the "dim" side of the lights to work separately from the turn signals. I have installed the resistors that came with the tail light across the turn signal circuit, that helped out with the tail lamp not working when the turn signal lights are wired correctly, but the turn signals and markers still won't work wired this way. For now I decided to let the marker lights be full bright and flash with the signals on.
The second weird problem:
Fast signal flashing....I know, replacing filament bulbs with LED's will do that. But even with resistors across the signal circuits, they flash fast. I've even gone to the point of temporarily wiring in resistors and extra filament bulbs just to see what it will take to slow them down. It took a headlamp bulb in the circuit to finally slow them down...but that sucked so much juice, the LED no longer lit up 100% and you could see the the bikes headlamp flicker at the same pulse rate as the signals.....
something crazy going on here. All ground test good with my multimeter as well as the power wires.....it's almost as if something is bleeding across circuits or feeding back through.
at this point I am ready to let the biotch flash as fast as it wants to as long as it works,LOL
First of the weird:
